Display problem
I'm trying to use media engine, but when I start it up I only see a portion of the interface. I'm using a VIA M10000 with the resolution set to 800 x 600 (but I tried higher). How do I fix this?
I figured it out. I had large fonts enabled under the advanced display properties.
Were you using the TV out?
thats a good thing to know, for future reference
Yes I was using the TV out, but I also had a monitor too. It showed up improperly on both the LCD and the monitor. It would be nice if I could use Large Fonts and still be able to run media engine.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
