Is there a trial version of MapPoint to download anywhere??
I can only find it as a demo CD, which comes from the US.
Printable View
This copy just fell on my desk :D out of the sky
P2P just try a download client like ;) http://www.edonkey2000.com
You did not hear this from me :rolleyes:
skoda, i thought there'd be a problem with your euope people with the longitude. I'll release a fix for that in a few hours
0.4beta is now there for testing. Here are some things it should fix
- Fixed the longitude problem in Europe.
- Fixed a few more memory leaks. There is still one when it deletes all of the pushpins. We are losing around 3 megs of memory an hour
http://www.zcentric.com/gps/GPS-0.4beta.exe
0.5beta is out now.
- FINALLY got the last memory leak! YAY. Instead of deleting all the pushpins I am just moving the current one to a new location. We seem to be around 4k every 10-20 minutes which is normal for windows.
http://www.zcentric.com/gps/GPS-0.5beta.exe
Also I'd like to know if people will actually use the arrows. I'm needing a way to add an option to insert a end location.
Is there any update to this?
What about MapPoint 2004?
OK, I ahve mappoint installed. What do I need to do with the MediaEngine GPS addon to use it?
Also, As I have Mappoint installed to use AGPS as default, will ME use the AGPS addon too?
Does the GPS addon work with ME2
mappoint 2004 i'm not sure.. it should work but i dunno.
its not really an addon.. just a test file. agps won't work since i'm using the sdk for mappoint. I'm doing everything agps is doing but more
Ah, OK cheer fella. thanks for clearing that up.
Will the source code for htis be released?
