This copy just fell on my deskout of the sky
P2P just try a download client likehttp://www.edonkey2000.com
You did not hear this from me![]()
Is there a trial version of MapPoint to download anywhere??
I can only find it as a demo CD, which comes from the US.
More info here----> http://www.gijsje.net
skoda, i thought there'd be a problem with your euope people with the longitude. I'll release a fix for that in a few hours
'98 Explorer Sport
80% done
0.4beta is now there for testing. Here are some things it should fix
- Fixed the longitude problem in Europe.
- Fixed a few more memory leaks. There is still one when it deletes all of the pushpins. We are losing around 3 megs of memory an hour
http://www.zcentric.com/gps/GPS-0.4beta.exe
'98 Explorer Sport
80% done
0.5beta is out now.
- FINALLY got the last memory leak! YAY. Instead of deleting all the pushpins I am just moving the current one to a new location. We seem to be around 4k every 10-20 minutes which is normal for windows.
http://www.zcentric.com/gps/GPS-0.5beta.exe
Also I'd like to know if people will actually use the arrows. I'm needing a way to add an option to insert a end location.
'98 Explorer Sport
80% done
Is there any update to this?
What about MapPoint 2004?
OK, I ahve mappoint installed. What do I need to do with the MediaEngine GPS addon to use it?
Also, As I have Mappoint installed to use AGPS as default, will ME use the AGPS addon too?
Does the GPS addon work with ME2
4x4 in a turbo stylee.
mappoint 2004 i'm not sure.. it should work but i dunno.
its not really an addon.. just a test file. agps won't work since i'm using the sdk for mappoint. I'm doing everything agps is doing but more
'98 Explorer Sport
80% done
Ah, OK cheer fella. thanks for clearing that up.
Will the source code for htis be released?
