Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 61
Thread: VOTE for parallel port relay control in ME
  1. #41
    FLAC Mastero's Avatar
    Aug 2001
    India
    Oh i forgot only about this exe..
    i shall post the exe
    do you want the exe for ME with built in a/c application?
    Mastero
  2. #42
    Jun 2003
    hay OdysseyPC got any more info on these usb relay control.
  3. #43
    May 2003
    yes, usb relay control is realy cool, because usb i have in my car everywhere, then i can connect where i want. no more extra cables! cool- how can we test the exe with control built-in the mediaengine?
  4. #44
    Feb 2003
    Essex, England
    Is there a kit for USB...??
    Where is best to get it from?
    Ta
    Gavin
    Of all the things I've ever lost my sanity was the hardest to deal with
  5. #45
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Quote Originally Posted by Mastero
    Mastero
    Yes please. Also, is there a specific order in which each device is plugged into the relay board? Such as a command programmed for A/C is sent through relay 1, but say my AC is mistakenly hooked up to relay 4, might it end up unlocking my door instead of controlling AC? Just wondering about some clarification, if what I'm saying doesn't make sense, I'll try to explain better. Thanks.
  6. #46
    Aug 2001
    India
    I understand this perfectly .. solution "click and connect"
    So you know which button using which relay
    Mastero
  7. #47
    Aug 2001
    India
    Control your a/c with ME
    OK friends here you go, this will convert your ME to control your relay board and thus control your a/c or any thing else you have conected on it.
    GET IT HERE
    There are three files and one folder
    Put the following in the ME folder
    mediaengine.exe
    inpout32.dll
    Rest put in the ME skin dir.
    This is specially designed for My Mercedes.
    Let me know what you think.
    NOTE:~
    YOU WILL HAVE TO DO 2 THINGS
    a) set an external application any exe file it doesnt matter.
    b) uncheck keep ME on focus
    your good to go then.
    Have fixed 99.999% of all bugs. A big thanx to Confussed for all his help.
    Cheers
    Mastero
  8. #48
    Feb 2003
    Essex, England
    Is this for Parallel / USB... both?
    I realised {dumbass] that I got my LCD hanging off of parallel so I too am interested in USB...
    Is there a circuit out there or a kit... What is the cheapest way to control 8 relays
    Thank you for putting up with my stupidity.
    Gavin
  9. #49
    Aug 2001
    India
    its parallel ....
  10. #50
    Newbie CoolDaddyAndy's Avatar
    Sep 2003
    Oak Creek, WI
    I vote yes, it would be awsome to be able to control the rest of my car from ME, rather than using another ext. app.
