um mastero when i replace the files u said to do it dosent work anymore. the screen just flashes black and then back to my desktop then black over and over until i clos it with ctrl+alt+del how do i fix tis.
Originally Posted by CoolDaddyAndy
Its already integrated ////
mastero
What exactly have you done ? explain in details
mastero
ok i figured out how to get it to work with ME 2.0 well i dont know if it realy works because i dont have a relay board to test it on but this way it makes it open
as well as the file mastero gave u u need a gif called logotrans.gif in the ME file
i also had to reapply all my settings for it to show on the screen propley( all the check boxex are un checked)
this is the file i used i know it is not a very good pic but it works.
all it realy is doing is changing it back to verson 1.7 something but it is easier this way then re installing it
I vote yes...
Code has been doen all he needs to do is take somesone code and make a quick page should take an hour or so at most...
im sure 1/4 of epople will use it at least.. how many use the radio option?
Can you make it to just control an 8 relay board? not specific to your Mercedes? or will it already... also do you loose any stability, options or features with it moving back to ME 1.7??
Well then, someone post the code.
Get MediaEngine !!!
Media Engine Download
Not sure if this will help you but there is a C source on this page with some scripts and such...
http://www.thebells.net/Halloween/PLCC/PLCC.html
