Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Hows your D-Link USB radio Reception?
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    Mine works fine software wise, but when you actually get in the car and use it, it sucks really bad. I have tried it hooked to normal antenna and car antenna. Still sucks. Its grounded correctly to car antenna, so don't think thats it. Maybe rate your reception on a scale of 1 to 10 with 10 being "attached to the radio tower itself" and 1 being "reception would be better on the moon with only teeth braces to pick up the signal"
    Please help...
    Get MediaEngine !!!
    Media Engine Download
    FLAC Mastero's Avatar
    Aug 2001
    India
    i say its "6"
    Variable Bitrate MeanGT's Avatar
    Jul 2003
    Melbourne, Florida
    CarComp,, how is the sound quality of the Dlink FM receiver?? The only way I would consider ditching my head unit for one, is if the quality matches that of regular radios,, (other than the reception problems)
    Newbie d20180's Avatar
    Aug 2003
    5, ok for strong stations, nonfunctional for weak. (using radiator drivers and car ant.) Repeated searching (scan forward) will bluescreen XP pro.
    Aug 2003
    LIttle Rock
    This is discouraging I just decided to get rid of my head unit but it sounds like the USB FM radio does not work? Is there anyone who is having any luck using thier Car Computer as an FM Radio???
    Check out the progress of my carputer at http://www.monkeytails.net
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    I've used mine with some success, although the reception could be better. Having said that, I paid very little attention to adequately shielding the cable, so it's no real surprise that it was shocking.
    There have been other threads on this device and issue that suggest very careful cabling, shielding and terminating can result in acceptable reception.
    I don't understand the need for heavy use of the scan button - I have all the stations that I am interested in set up on my station list in radiator.
    Sure it's not a fix for the BSOD issues you have, but it might be a sufficiently elegant workaround.
    C!
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
    GTC
    GTC is offline
    May 2003
    Canada
    Mine seems to work fairly well, though I've ditched the d-link attenna in favour of patching into the cars attenna system ($1.50 for the car antenna extension cable at Rat-Shack, and 15 minutes of cutting and soldering - plug&play when I got it into the car!).
    GTC
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    My carputer is still in drydock in my house and the D-Link FM works fine there. Good reception and good sound. If it works as good in the car, I'll be very happy.
    Jun 2003
    Chicago
    I would rate the DLink reception as 5, only strong stations come in and even they have static. I have the antenna connected to my car antenna.
    C4M
    C4M is offline
    Apr 2002
    Sydney, Australia
    I've heard of good reception using these (and I can't recall who it was). Achieved by desoldering the RCA connector from the board, placing the board in a shielded enclosure, and running cables off the board directly to the antenna lead.
    When mine goes back in the new car, I'll be doing some experimenting.
