I believe, from my basic playing around, ME uses the settings in winamp.ini. I can't actually see a ME .ini file...so I can't put any settings there! Unless you're talking about settings.ini, in which case, there is nothing about Winamp in there!
If it's not using the right output plugin...try renaming the output plugin you want to use as out_ds.dll, and rename that original file to something like out_ds.old, so you can change back easily
Garry
LinkBack URL
About LinkBacks
