Results 1 to 10 of 18
Thread: Media Engine 1.7.7.F using Creative Labs remote.
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    Ok so this problem has been buggin the living crap out of me. Its been going for over a week now. I even ordered a new remote on eaby still the same exact problems. I unistalled - reinstalled ME still the same problem. Changed comms port from comm 1 to 2 and still the same problem. What give? plz help me out.
    The problem is that when I input or try to program the remot in ME, instead of doing what its suppost to do ei:
    instead of stoping the track it will mute.
    volume up, it will mute.
    colume down it will go to the next track, I got all kinds of whacked out errors.
    plz any help on this matter will be greatly apreciated.
    plz no "use girder" replies. I really dont want to use grider, cause I use ME full time.
    thanks for your time.
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Try this wee app i made for my creative remote. The reciever has to attached to com1. It should tell you if its putting out the right signal. at this stage i haven't tried the remote with ME. i will after this post.
    You will need to have the VB runtime files installed.
    Attached Files Attached Files
    We are, will have and forever will be...
    But not tommorrow!
    Jul 2003
    I see what you mean. i used the IRMAN option, it seemed to be the only thing that recognise the commands. But i think that the problem lies there. Are you using IRman or creatives reciever. I think that the creative remote needs to be programmed in manually, unless someone else has got theres to work.
    I will have a go - i've got the current source code.
    But not tommorrow!
    Jul 2003
    Well i tried, they way the have coded the remotes is beyond me - it seems too complicated for just taking a command and processing it.
    So it looks like coding wise, the creative infra can't be used. unless you purchase a irman receiver or if carcomp adds the remote in (which would be a good suggestion for v2.0
    But not tommorrow!
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    a developer would have to have that remote to code it in..
    '98 Explorer Sport
    80% done
    Feb 2003
    South Florida
    HMMM makes me wonder, cause I saw Defilers setup run just fine. He was using the creative labs remote.
    SO you did get the same errors?
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    This is very odd...Maybe carcomp can shed some light on this?
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Variable Bitrate MeanGT's Avatar
    Jul 2003
    Melbourne, Florida
    I have the creative remote, and it works fine, (I assume you are talking about the one that is credit-card sized) The only way I could get it to work was to set the remote type to "Creative CIMR" and then choose the right com-port, works like a charm now,,
    Feb 2003
    South Florida
    Yeah I have done that million times. With two remotes, and two recievers same problem. On Both!!
    Jul 2003
    Quote Originally Posted by osirisdon
    Did the remote work with my app?
    But not tommorrow!
