Results 1 to 6 of 6
Thread: D-Link DRU-100 Hack
    Low Bitrate SurfinCajun's Avatar
    Mar 2001
    Naples,FL
    D-Link DRU-100 Hack
    Can anyone tell me how to hack the usb radio to work with my car's antenna? I think all I have to do is get a car antenna extension and just splice it but I'm not sure. Any help would be appreciated.
    Jun 2003
    Chicago
    Quote Originally Posted by SurfinCajun
    You can try just splicing it (car center pin to Dlink RCA ground) however I have found reception to be poor. There is another thread out there that mentioned taking the radio apart and soldering directly to the reciever....I havent' tried this myself
    Maximum Bitrate orangewhip's Avatar
    Apr 2001
    Surrey, B.C. Canada
    Quote Originally Posted by EBJUSTIN
    Car center pin to Dlink RCA? Is there not 2 wires on both the car antenna and an RCA? I have in fact desoldered the RCA connected on my board and have soldered it stright to a antenna cable...but I haven't actually tried it yet.
    OrangeWhip? OrangeWhip? 3 OrangeWhips!!
    www.whipflash.com
    Finally a new Avatar!
    Jun 2003
    Chicago
    The car antenna is essentially one signal wire and ground. The signal wire is the center pin and shoud connect to the outer housing of the Dlink RCA connector. A standard RCA connector uses the center pin for signal and the outer housing for ground but Dlink 'broke the mold'. I don't know what they were thinking. They should have used a standard RF connector (coax maybe).
    Apr 2001
    Surrey, B.C. Canada
    Really, how can you tell it is backwards? I soldered it to the board thinking that the outside was the ground...but like I said I haven't tried it yet. Could that be why your reception is poor?
    I'm not trying to knock what you are saying, just trying to figure it out for myself. On the actual D-Link board, do you know what one is signal and what is ground?
    www.whipflash.com
    Jun 2003
    Chicago
    Quote Originally Posted by orangewhip
    RCA center pin is ground, and ground is signal.....other people have noticed this too
    my Dlink USB FM Radio to Car Antenna Adapter
