Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
Thread: My changes to ME v1.7x
  1. #11
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Quote Originally Posted by Confused
    Lemme know some file extensions you want to play, and I'll add support for those extensions, but whether it will actually play them, you'll have to find out for me
    .MOV is really the big one I would like.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  2. #12
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    From looking at the source code, integrating QuickTime support into Media Engine 1.7 would be quite a project...
  3. #13
    FLAC Mastero's Avatar
    Aug 2001
    India
    could you please do something about the shutdown in win98se..thats my os. when i hit the shutdown key it just logs off and back on .. PLEASE NEED THIS ASAP !
    It shall be nice if i could send it to standby mode.
    mastero
  4. #14
    Jan 2002
    Temple Terrace, Fl.
    One other thing...When scrolling through songs or movies, is it possible to have the highlighted bar stay in the middle of the list so it won't go all the way to the bottom of the screen? This way you can see the next few songs/movies in both directions.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  5. #15
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Quote Originally Posted by Defiler
    AS far as i'm aware .mov (quicktime) is basically non-existant, there is no activex avaliable from apple for Win32 developers to use except for a NON-FREE one avaliable here http://www.skylark.ie/skylight/default.asp.
    I have heaps of movie trailers (in .mov format) which i'd love to play in my CarPC, but i can't find a lot of info for implimenting mov playback in a windows app.
    We are, will have and forever will be...
    But not tommorrow!
  6. #16
    Jan 2003
    Ruston, LA
    quicktime alternative installs a codec that can be used
    of course someone will have to integrate support for it into winamp...
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  7. #17
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    Talking
    I could I get a Nightime mode? Playlist support would be great. And maybe DVD support. And if you could throw in integrated GPS that would rock. Hmmm. Maybe at this rate the "people" might have ME 2.0 after all
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
  8. #18
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Quote Originally Posted by Naamanf
    Hehe!!
    I won't be able to make it into V2, my VB knowledge isn't too brilliant, just enough to make basic changes
    At the moment I'm struggling to get it so that when you go up a directory in the playlist screen, you don't go back to the beginning of the list, but go to the point you were last at. I've nearly got it, but not quite! [Edit] Got it working now! [/Edit]
    I have also noticed a problem, not sure if it's just me or whether it will be with everyone. If you have "Resume playback from last position" enabled, as well as "Load to MP3", when you resume from standby/hibernation, it will crash out. I'm not too sure why, but if you disable either of those options, it will work fine. I'll try and sort this asap. It's annoying (especially as i'm at work!) cos it only happens when the EXE is compiled, and when resuming from shutting down, so it takes a long time to try and debug. Also, there's no error messages either, so I don't know what's goin on! [Edit] OK, I've added a couple of lines, it worked OK first time I tried on my laptop, but ME wasn't set as Shell (as it has been the last times I've had it happen. I have uploaded the latest EXE file, I would appreciate it if you test it and it doesn't work to tell me! I shall also test it fully when I get home from work in about 4-5hrs. [/Edit]
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  9. #19
    Aug 2003
    Amarillo, TX
    For those of you who really want to see quicktime in your car in MediaEngine or the other players that use WMP or DirectShow-based playing, you can convert your Quicktime to AVI or MPEG easily enough with Discreet's Cleaner. (That is a company and a product by the way.) .. Cleaner can basically take any input and produce any output.. This includes ASF and RealMedia files. It also does not care about copyright protection bits on the files (a real problem with trying to convert Quicktime files)..
    It's really a fantastic product...
  10. #20
    Aug 2003
    Essex, England
    Uploaded latest EXE, which i HOPE has fixed the crashing when it loads to MP3 screen when "Resume playback" is enabled.
    I hope!
    Please test it and let me know if it all works or not!
    Garry
    www.aimee.cc
