Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 42
Thread: My changes to ME v1.7x
  1. #31
    Jul 2003
    So. Cal.
    media player classi
    the quicktime alternative and real alternative both play thru media player classic, which will play any codec you have installed. so maybe a way to change the default player? because you can't (afaik) change it in xp, it just changes back. would this cause too many problems? would be nice though.
  2. #32
    Jan 2003
    Ruston, LA
    Quote Originally Posted by gork
    BTW anyone know how to get around VB totally crashing out when you start subclassing stuff? I have tried to find an answer and can't.. I'm running VB6 straight from the CD's (ie not upgraded to SP5) .. guess I should at least try upgrading before I continue complaining about it..
    you can get some dlls to make it a little easier (so you can debug subclassed code)
    but the short answer is don't have any errors in your subclassed code, and disable subclassing if you need to debug.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #33
    Low Bitrate SonicCobra03's Avatar
    Sep 2003
    STL
    Can someone plz post the updated .exe again
  4. #34
    Jan 2003
    Ruston, LA
    confused, can you post your modified source, I want to do some changes but I like the fixes you've made, no since in redoing from scratch
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  5. #35
    Apr 2003
    milan, mars
    first of all thanks confused for the updated exe. Good work and now i can listen to music while destinator 2 is on.
    What i have probems with is that i installed milkdrop viz latest build. What happens is that it crashes 3 times out of 4. i have a epia m 10000 ezra core with 64 m of memory enabled. from what i have managed to see between the total crash of tha system it seems that i get the message that there are problems with my memory card which cant initialize the 3d engine..... so, i launch winamp in the mediaengine directory and fiddle with configuration of milkdrop. i tried diffrent resolutions, also tried to lower to 16 bit depth. i dont know how to solve this "vital" problem, dont think its the direct x version which i have installed, 8.1 causing the problem. ill update to latest 9.0a if necessary.....
  6. #36
    Mar 2002
    Long Island, NY
    how about wma support?
    Grand AMplifier Project 1.0:
    http://drive.to/cliffsgrandamgt/
    http://www.astallaslions.com/carmp3/
    -Eden 800 mini-itx motherboard
    -5.6 NTSC TFT-LCD
    -80 gig hard drive
    -128 MB RAM
    -MPBS1 DC-DC PSU
    -PB Remote /w Girder
    -Media Engine & Windows XP
    -Playstation II also added
    -Steering Wheel Buttons modified for Control.
  7. #37
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    susman,
    Not sure what's going on...maybe latest build?
    I am using the one that you get from Winamp.com. Will try the latest build tonight however.
    Cliff, not sure why people use WMA, but you got it, will update exe later
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  8. #38
    Apr 2003
    milan, mars
    updated to latest direct x problem persists seems to get even worse now....installed geiss viz latest build that doesnt give me problems.....shall try milkdrop not the latest and see what happens....
    PROBLEM OCCURS ONLY WHEN XP COMES OUT OF HYBERNATION. DOESNT RELOAD PROPER DRIVERS???
  9. #39
    Maximum Bitrate MikeHunt79's Avatar
    Aug 2001
    Cambridge & Bristol, UK
    Also, AAC and MP4 support would be great... My winamp on my home PC plays these fine with the plug-in.
  10. #40
    Newbie STIdev's Avatar
    Oct 2003
    Maine
    Smile
    Confused,
    Can you post the source for your changes for your fellow developers?
    Thanks.
