Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 68
Thread: ME 2.0 Official Bug Reports
  1. #21
    Maximum Bitrate phat_bastard's Avatar
    Sep 2002
    St.Louis, MO
    Quote Originally Posted by Sungleassesron
    Updated the .exe today but am still getting an error every now and again, 2 small windows pop up one saying switch to and retry, somehting about application is already in use? does this mean anything to you,
    Are you running the latest version of the .exes? If so, I need more details about what you were doing when you noticed this.
    Quote Originally Posted by Skraggy_uk
    Managed a strange thing though.
    Had an album running in MP3. managed to get to the media library, and select a DivX movie.
    I actually noticed this problem over the weekend while I was fixing another bug. We're tyring to tackle some other issues and should have another bugfix release ready very soon.
    '01 Chevy Xtreme Stepside (pics)
    FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
    WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
    350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
  2. #22
    Oct 2003
    Northampton, UK
    ME2 loops on start.
    debug log.
    28/10/2003 00:54:33 - db background update initiated
    28/10/2003 00:54:33 - An error occured in modDB.UpdateDBMain last_sql= : Object variable or With block variable not set : Error number 91
    28/10/2003 00:54:34 - db background update initiated
    28/10/2003 00:54:34 - An error occured in modDB.UpdateDBMain last_sql= : Object variable or With block variable not set : Error number 91
    28/10/2003 00:54:36 - db background update initiated
    28/10/2003 00:54:36 - An error occured in modDB.UpdateDBMain last_sql= : Object variable or With block variable not set : Error number 91
    28/10/2003 00:54:37 - db background update initiated
    28/10/2003 00:54:37 - An error occured in modDB.UpdateDBMain last_sql= : Object variable or With block variable not set : Error number 91
    This repeats forever.........
    Updated to the latest on mediaengine.org today.
    Previously ran fine before this!
    Used unregger
    Restarted it 4 times to clear the message windows
    It starts ok, mediaengine big logo, then main screen, then jumps to loading then back to main screen, over and over.........
    Home PC - key/mouse
    Xp2400AMD
    256mb
    Sure its something obvious!
    Scott
  3. #23
    Aug 2003
    Bristol - UK
    [QUOTE=phat_bastard]Are you running the latest version of the .exes? If so, I need more details about what you were doing when you noticed this.
    here is a pic i took while on the road, it only happens now and again, sorry for the ****e quality, but had to use my phone to take it, as I was driving at the time.
    Also when I use Shutdown I get a DLL error on exit, do you know what this is, I will find out the name tommorow, its very quick flash up
    www.fsplanes.net NEW site
    AMD XP 1800+ / 256mb ram ddr / 2 x 60gig hdd / Asus mobo micro ATX / GF-FX5200 / BU 303 GPS reciever / dlink usb radio
    Software:
    Window's XP SP1 / USB Radio / Destinator v2 / Mediacar / 3000 mp3's / 30 movies
  4. #24
    dob
    dob is offline
    Oct 2003
    An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path,...
    here is the scenario:
    1. instaling MediaEngine2.0.20setup.exe
    2. exec UnRegger.exe
    3. update mediaengine.exe and DB_UPDATE.exe
    4. start mediaengine.exe (3 times I think)
    5. start mediaengine.exe -> now it starts continiously restarting itself, it's hard to kill it (click settings and then taskmanager end process)
    6. again start mediaengine.exe - in the settings dialog I have blinking yellow light -> DB offline
    please help ... tell me what to do, if steps 2 and 3 are ommited ... the same problem
    /////////////////////////////////debug.log/////////////////////////////////
    MediaEngine Version 2.0 Build 2.0.19 - Logfile created on 29.10.2003 ã.
    29.10.2003 ã. 21:28:21 - db background rebuild initiated
    29.10.2003 ã. 21:28:21 - An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path, TStamp, Title, Artist, GenreID, Album, MediaType, ParentDir) VALUES('\mp3\Experience\1.mp3','07.3.1999 ã. 10:54:34','Everybody In The Place','Prodigy',1,'',1,'\mp3\Experience\') : [Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression. : Error number -2147217913
    29.10.2003 ã. 21:28:23 - db background update initiated
    29.10.2003 ã. 21:28:23 - An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path, TStamp, Title, Artist, GenreID, Album, MediaType, ParentDir) VALUES('\mp3\Experience\1.mp3','07.3.1999 ã. 10:54:34','Everybody In The Place','Prodigy',1,'',1,'\mp3\Experience\') : [Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression. : Error number -2147217913
    29.10.2003 ã. 21:28:25 - db background update initiated
    29.10.2003 ã. 21:28:25 - An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path, TStamp, Title, Artist, GenreID, Album, MediaType, ParentDir) VALUES('\mp3\Experience\1.mp3','07.3.1999 ã. 10:54:34','Everybody In The Place','Prodigy',1,'',1,'\mp3\Experience\') : [Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression. : Error number -2147217913
    29.10.2003 ã. 21:28:26 - db background update initiated
    29.10.2003 ã. 21:28:26 - An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path, TStamp, Title, Artist, GenreID, Album, MediaType, ParentDir) VALUES('\mp3\Experience\1.mp3','07.3.1999 ã. 10:54:34','Everybody In The Place','Prodigy',1,'',1,'\mp3\Experience\') : [Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression. : Error number -2147217913
    29.10.2003 ã. 21:28:28 - db background update initiated
    29.10.2003 ã. 21:28:28 - An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path, TStamp, Title, Artist, GenreID, Album, MediaType, ParentDir) VALUES('\mp3\Experience\1.mp3','07.3.1999 ã. 10:54:34','Everybody In The Place','Prodigy',1,'',1,'\mp3\Experience\') : [Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression. : Error number -2147217913
    29.10.2003 ã. 21:28:30 - db background update initiated
    29.10.2003 ã. 21:28:30 - An error occured in modDB.UpdateDBMain last_sql=INSERT INTO Media(Path, TStamp, Title, Artist, GenreID, Album, MediaType, ParentDir) VALUES('\mp3\Experience\1.mp3','07.3.1999 ã. 10:54:34','Everybody In The Place','Prodigy',1,'',1,'\mp3\Experience\') : [Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression. : Error number -2147217913
  5. #25
    Newbie EE8Racer's Avatar
    Jun 2003
    Middelstum/ The Netherlands
    As I wrote in an e-mail to phat_bastard With the new updated files the problem that ME2 is restarting all the time is gone! Now it just shuts down :S
    This is what my debug.log says.
    MediaEngine Version 2.0 Build 2.0.19 - Logfile created on 10/30/2003
    10/30/2003 7:09:41 AM - db background update initiated
    10/30/2003 7:09:42 AM - An error occured in modDB.UpdateDBMain last_sql= section: 8 : Object variable or With block variable not set : Error number 91
    I have updated with the new exe files. 2.0.26 and 1.0.7.
    I hope you can find the problem because dispite all the updates the problem isn't solved.
  6. #26
    Low Bitrate QuickCarl's Avatar
    Jun 2003
    Atlanta
    Quote Originally Posted by phat_bastard
    Remember, you paid how much for MediaEngine? We've invested quite a bit in hardware to test with, domain registration fees and numerous other expenses, not to mention the time involved, and we give away the software for free. Is a little patience and understanding so much to ask from you?
    I have been working with phat_bastard myself over that period of time. I have found him to be helpful, understanding, and knowledgable. I think that given the circumstances they are dong an outstanding job.
    My issue has been resolved totally and I am looking forward to 2.X releases and using the software on my system.
    I encourage everyone to be as detailed as possible when providing information about problems they are having, which may include taking notes. We all want the same thing. The developers ware doign great in my book. JMO-Carl
  7. #27
    Newbie thomas_schaefer's Avatar
    Oct 2003
    Hi!
    First: Great Software!!! I´m happy that you write these kind of Software....
    But:
    I´ve got a VIA Epia V8000 with Win98SE on it and a 7" Xenarc Touchscreen.
    When I´m running a resolution of 800x600 and 16 or 32Bit then the writing of the
    lists are scrambled, they are overlaying when I scroll down the list or select another file to play. The same is in the "Browse Media" list.
    On 1024x768 there´s everything allright. The same in 800x600 and 256Colors.
    I´m using the default skin. WMP9, DX9.0b installed.
    And I´ve another Problem:
    When I press the shutdown button, ME is trying to shutdown, but in the background a loginmask appears with the username im logged on.
    Then ME hangs, and cant shutdown.
    Is it a bug or a settingfailure?
    Greetz
    Tom
  8. #28
    dob
    dob is offline
    Oct 2003
    Quote Originally Posted by GTC
    dob - what is the " ã " character I see through your post? In the SQL Statement, the reference to '07.3.1999 ã. 10:54:34' probably isn't valid as the expected field is probably a date/time.
    The developers may want to cast that value to a date/time before entering it into the database, or better yet format it as a string using explicit formatting (as the cast "cDate" would probably be locale specific and may not play happy with Access ... ) ...
    dob - If you want a quick fix, you might try changing your settings (I'm guess locale settings, but not completely sure) to remove this character ...
    Because the log is strewn with "[Microsoft][ODBC Microsoft Access Driver]" it is likely that some version of MDAC (or at least the Access drivers) are present.
    cheers,
    GTC
    ã is г.
    this is year in bulgarian
    I'll try this with tha locale setting .. 10x
  9. #29
    Sep 2002
    St.Louis, MO
    Quote Originally Posted by frodobaggins
    You should also update, current ME version is 2.0.20 as in the sticky
    Actually it's .27 currently, I neglected to update the sticky.
    Also there was some mis-communication between myself and CarComp that caused 2.0.19 to be written to the logfile with the actual program version being 2.0.26 [dont ask].
    Also, any problems we've seen with mediaengine not referencing the support .exes seemed to have been resolved by running unregger.exe and then re-launching the app until it gets everything re-registered.
  10. #30
    Apr 2003
    Åmynne, Sweden
    Can you fix the onscreen keyboard to support
    å, ä, ö i mean å, ä, ö
