Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 68
Thread: ME 2.0 Official Bug Reports
  1. #41
    Maximum Bitrate phat_bastard's Avatar
    Sep 2002
    St.Louis, MO
    Quote Originally Posted by nicgalla
    Dear Phat
    I have discovered it's not a bug related to Safe Volume option. It seems that ME loses some keypresses. Yesterday it forgot volume up and volume down, while the other keys on my keypad worked well. I have reassigned them and now I can turn the volume up to the maximum.
    To be on the safe side I tell you this is not affected by caps lock status, otherwise any key won't work.
    What about NumLock? We've used the same keyboard code since 1.13, never had keys get 'forgotten' before. If you programmed volup / voldown to keys inside your 10-key pad, and then NumLock got turned off you'd have the same problem.
    Quote Originally Posted by ccsnet
    *Problem - I managed to hang Media Engine good an proper
    *What type of input device - Mouse
    *Fresh install of ME, Build the data base after setting the dirs. Start, go to browse media play MP3, go to home try movie - fail, back to browse media, select by acident a .mov file.. and bosh.
    *Text from any error messages you might be seeing - Just hung, unable to grab any thing except even End task failed.
    *Steps you've taken (if any) to resolve - Don't do that again...
    *Lines from debug.log that may be relevant - See above
    See what above? Because m/e hung doesn't necessarily mean nothing was written to your debug.log file.
    *Screen captures if absolutely necessary - See above
    *Brief description of your pc config, speed, memory, os, etc - IBM Think Pad T20, XP SR1 all patches inc latest version of MMP. 256 Mb Mem.
    Although you did make an effort, I still have to give you an F on your bug report. Reason: no version numbers. ;-)
    Seriously, you might try playing the movie you said 'failed' first in WMP (outside of MediaEngine) and see if you have the necessary codecs installed. You also didn't specify what type of file that was. If the quicktime movie you attempted to play was something compressed with recent quicktime codecs, WMP won't be able to play that either. Wish we knew how to tell if WMP has errored out looking for codecs. Anyone have ideas?
    '01 Chevy Xtreme Stepside (pics)
    FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
    WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
    350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
  2. #42
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by phat_bastard
    Well it was late... The answer to that would be no I don't have the right codecs for WMP but I do have Quicktime installed... Any way it was more a 'Dont do it this way every one msg' ..
    An F - Well its an improvment from what I used to get - LOL ( Sit with big cheesy grin remembering getting told i'd never amount to any thing - then thinking about what I am doing now..... ) lol.
    Terran
  3. #43
    Jul 2003
    Milan, Italy
    well it seems to be a CapsLock related problem. Unfortunately this keypad doesn't have a Capslock LED. I'll check it out and set the bios option accordingly.
    It could be a nice idea to support Capslock status, you can make 2nd function like scientific calculators...
    -NicGalla-
    custom-made aluminum case | MK2.8+ PSU | EPIA 800 | 256 Mb DDR | 120 Gb 7.2k WD | Wireless Chieftec mouse & keyb | Trust USB Keypad & USB webcam | Majestic TFT 7" 16:9 | WinXP & ME2 | connected to factory head-unit in a PT Cruiser 2.0L
  4. #44
    Sep 2002
    St.Louis, MO
    I really don't think it's a capslock related issue, but maybe numlock. Capslock doesn't change the keycode that we get and store in your kb.ini file, if I recall correctly.
    I doubt we'll support any kind of shifted button feature for keyboard input, it's not an extremely popular input device for dedicated carPCs.
  5. #45
    Jul 2003
    Milan, Italy
    D'oh! well I know that most used input device is touchscreen, but believe me, small LCD screens w/ touchscreen are quite rare and very very expensive at least in Italy.
    There is a italian reseller who has the famous Xenarc monitors but they cost near 600 euros which is more than what you spend for every other components...
    Yeah I was wrong, I was referring to Numlock... capslock is totally another thing :|
    -NicGalla-
  6. #46
    Oct 2002
    UK
    bug found
    I have the 'Power off' command configured on my remote using IRMAN. When I execute this command my laptop running Windows 2000 sp4 successfully goes into standby mode. However on resume from standby mode ME2 is not actually on view in the programs bar. The 4 programs are still running in task manager but they arnt actually showing, just running invisible in the background.
    To fix this I have to load task manager and end all the 4 tasks, then re-open ME2.
    see sig for my setup
    Also another problem I have is after returning from playing a vis and then going back in to the main menu, about 2" of the right hand main screen is chopped off (just a black area). To fix this I have to clsoe and re-open ME2.
    Volvo C70 - Installation in progress *gulp*
  7. #47
    Dec 2003
    OK read all the reports, I think i have two problems quite unique.
    I have 500mhz (128mb ram) PII Win98se box - running .27 latest ME binary, and when I go 'startVis' the vis will start, but no matter what i do to exit, it will turn off and on with every keypress after that.
    My other problem is when i choose to use me as shell, windows says "Error has occured loading C:\blah\ME.exe Please Reinstall Windows"
    and I have to go back in through DOS to change my shell= line back.
    Another thing i've noticed is that ME freaks if you try to add/remove etc files from a directory that it is updating it's database from, but this is entirely understandable and not a problem.
    Sorry one last thing is that my divx runs horribly but i think it is just underpowered machine.
    EDIT: Right forgot another thing, when I press 'Shutdown' then windows networking login pops up and an explorer window opens. Weird.
    Thanks.
  8. #48
    Variable Bitrate Goose's Avatar
    Dec 2002
    Europe
    It is too mutch bugs in ME2.0 so I have to use MediaCar
    ME2.0 does not even start on my Epia M (truyed to reformat hdd and reinstall Win XP, then reformated and reinstalled windows 2000 pro) and nothing.
    Is there any chance to get new patch for ME2.0?
  9. #49
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    Its not too much bugs in 2.0, probably just 1 bug holding you up... I bet if we had some one on one chat time I could help you out..
    And yes, we will be releasing another version soon... Yes, version, as in an installer... We have neutralized many many bugs since 2.0.27 (we are at 2.0.46 at the time of this posting)...
    MediaEngine is an extremely complex program. It does a lot more for you than you think. We strive to make this application function correctly, and truth is, I bet many people download it and use it without saying one thing in here. I have over 500 different people signed up for the mediaengine.org newsletter, and I only hear from a few of them about problems.
    Get MediaEngine !!!
    Media Engine Download
  10. #50
    Dec 2002
    Europe
    Cool I am looking forward to that
