I think I have a solution to solve this one without massive recoding, when I finish testing it and I'm confident it works properly I will pass the code along to carcomp and phat_bOriginally Posted by Sunglassesron
Frodo
I get this same problem alot, I had to switch Frontends... ME 2 is still pretty buggyOriginally Posted by Sunglassesron
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
okay, after having it all working, when i reloaded the system it only get to "refreshing database" until it crashes and says memory to low "run time error '6'" but the thing is that i have 1.3ghz and 256 drr so i wouldn't think it would just crash. M/e2.0 has loaded 105times while trying to refresh the database and i know thats why i get the memory error but how do i fix it ? also something that might be helpful is that i had a lot of songs in the playlist previously :S
After installing mediaengine some of the buttons doesn t work with my lilliput touchscreen after reinstalling the drivers the buttons work again.
Buttons that doesn t work are>
the volume buttons
moving up and down
and the play button
And I have a problem with the database every time he set in on alfabatic order(tag)
and in the setting.ini Have I changed it to sortonfilename=treu
I had problems with the buttons not working with a 10.4" touch screen.
I needed to recalibrate, and everything was fine after that. Didn't need to re-install.
4x4 in a turbo stylee.
But the touch screen worked fine in windows so I think it`s a bugOriginally Posted by Skraggy_uk
Hi, running ME ( Latest version with all the patches ) on XP and using the screen res or 848x600. The first screen is ok bar one button which was out by one pixel. I then went to the play back mode and there where loads of gaps... and the bits of the screen was distorted ( ie a chunk moved ) mostly round the mp3 logo up the top.
The skin was desinged and tested under 800x600... sorry I have got not screen shots and it does not stop the correct operation of the software... just looks a bit messy..
Terran
The next version handles any resolution you can throw at it, and you can even specify extremes like 3x5000 pixels.. Hehe.. But anyways all of the problems you mention have been taken care of and will be in the next release.Originally Posted by ccsnet
Get MediaEngine !!!
Media Engine Download
I dont know if ME is supposed to be able to play WMA's but if you add it to the list it seems to fine, the only problem is it isnt reading the ID Tags right, the track title comes out ok but the artist and cd are always unknown, all my WMA's are VBR encoded and labeled by windows media player 9
-spencer
I am having the exact same problem. Once the track get finish playing in Vis mode it freezes up and then a pop up asks to retry or switch to. I have to end the program using taskmanager. The WMP.exe stops responding and causes ME to crash. Do we have a work around for this?
