Page 7 of 7 FirstFirst 1234567
Results 61 to 68 of 68
Thread: ME 2.0 Official Bug Reports
  1. #61
    Jan 2004
    UK
    Quote Originally Posted by Tazzios!
    After installing mediaengine some of the buttons doesn t work with my lilliput touchscreen after reinstalling the drivers the buttons work again.
    Buttons that doesn t work are>
    the volume buttons
    moving up and down
    and the play button
    I have the same problem here
    MediaEngine 2.0.27
    DB Engine 1.08
    WinXP SP1
    Epia 800
    256Mb Ram
    40GB HDD
    Lilliput 7"Touch
    25point calibration
    The Touch screen works in windows in the area where the buttons are.
    If I turn on the mouse in Mediaengine the mouse moves to where the buttons are and the buttons almost flicker.
    Its almost like the calibration is wrong, yet its perfect in windoze.
    Keep up the great work
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    The buttons only light up and do something when you click them. Why else would they be buttons? They would have to be markers or something if they just stayed highlighted. This does not apply to the main menu though, since those are selections.... In the future, touchscreen mode will only highlite the button you touch as well. And only when you touch it. If you take your touch off, the button will go back to its "un pushed" state.
    And what do you mean by the buttons don't work? Like, when you click them nothing happens? Buttons not working implies a lot of things. Also, having your touchscreen set up where instead of a touch equals a mouse click, set it up so that holding your finger on the screen is equivalent to holding down the mouse button.... Some buttons are designed to repeat (so you don't have to bang your finger against the screen over and over)...
    Get MediaEngine !!!
    Media Engine Download
  3. #63
    Maximum Bitrate SiGmA_X's Avatar
    Jul 2003
    Portland, OR, USA
    I am patched to the latest as of today, and here's the error I'm getting. ME is restarting many times..
    1/6/2004 6:13:46 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:13:48 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:13:50 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:13:52 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:13:54 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:13:56 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:13:58 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:00 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:02 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:07 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:09 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:11 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:14 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:16 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:35 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:37 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:39 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:41 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:43 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:46 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:48 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:50 PM - An error occured in modDB.UpdateDB : : Error number 91
    What would that error be?
    1993 BMW 325is - 15.2sec
  4. #64
    Variable Bitrate streetknight's Avatar
    Dec 2003
    i installed me2.0 ver. today in my sys.
    VIA EPIA M9000 80GB 128MB
    LG Electronics 16x DVD-ROM drive
    os. winxp
    powerdvd
    wmp9.0
    the software is fairly new all the media has just been installed in the last week. its still not in the car yet.
    problem when i open the playlist and go to cd/dvd (with a dvd in side) it wont read it, but if i have a cd in side it reads it with out any problems. can some one help. i have read the thread and shreached no help. thanks in advance sam b.
  5. #65
    Jan 2004
    UK
    Quote Originally Posted by CarComp
    Yes !
    My screen was set to touch on release or something, i set it to normal and now it works great.
    Thank you CarComp
  6. #66
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Had a similar problem. Changed how it functioned, and did a re-calibrate and now it all works.
    4x4 in a turbo stylee.
  7. #67
    Dec 2003
    Quote Originally Posted by Nucrypt
    OK read all the reports, I think i have two problems quite unique.
    I have 500mhz (128mb ram) PII Win98se box - running .27 latest ME binary, and when I go 'startVis' the vis will start, but no matter what i do to exit, it will turn off and on with every keypress after that.
    My other problem is when i choose to use me as shell, windows says "Error has occured loading C:\blah\ME.exe Please Reinstall Windows"
    and I have to go back in through DOS to change my shell= line back.
    Another thing i've noticed is that ME freaks if you try to add/remove etc files from a directory that it is updating it's database from, but this is entirely understandable and not a problem.
    Sorry one last thing is that my divx runs horribly but i think it is just underpowered machine.
    EDIT: Right forgot another thing, when I press 'Shutdown' then windows networking login pops up and an explorer window opens. Weird.
    Thanks.
    Has anyone got any thoughts on these problems? i'm still having them and can't install my carputer untill i've worked them out..
    thanks
  8. #68
    Constant Bitrate psyclobe's Avatar
    Oct 2003
    ME is the best.... but there are these annoying bugs:
    If I have full screen visualizations and the song changes, the screen goes completely black. The mouse is still active, and I can go to the start menu if I hit the windows button, but media engine just doesn't come back and I have to kill it and restart it... This also sometimes happens when I come back from standby mode after having gone into standby mode when full screen visualizations were on..
    If I click on "videos" twice the application crashes
    Otherwise.. GREAT STUFF!
    P.S. Using latest build with patches from mediaengine.org. Hey need any help fixing bugs? I wanna help! [email protected]
