Page 1 of 7 1234567 LastLast
Results 1 to 10 of 68
Thread: ME 2.0 Official Bug Reports
    Maximum Bitrate phat_bastard's Avatar
    Sep 2002
    St.Louis, MO
    The other threads were getting a little full + off topic, let's have an official one here.
    Please take these steps before submitting:
    1) READ ALL THE BUG REPORT THREADS! The solution might already be here. DO NOT POST DUPLICATE BUG REPORTS unless you can add articulate information relevant to the bug.
    2) If you haven't already, go to http://mediaengine.org and download the latest binaries, mediaengine.exe and DB_UPDATE.exe; links for which can be located in the news section under the 2.0 Bugfix heading at http://mediaengine.org. Save these in your program directory (you should be asked if you wish to overwrite the existing files). The most current version of the mediaengine.exe binary is 2.0.27 and DB_UPDATE.exe is at 1.0.8. Check after install that you have this version by looking at the file properties in explorer.
    3) Read the readme.txt file located in your MediaEngine 2.0 program directory.
    4) Try deleting your settings.ini file and also your tags.mdb file just to be sure there wasn't a funky setting saved or a corrupted database record.
    What to include:
    *Bug report in consice language - "it doesn't work!", "it's soo slow!" or "i wanted (some) feature" doesn't help us, nor will it help you. The more detail you can give us, the quicker we'll be able to find the problem.
    *What type of input device (mouse, touchscreen, remote, keyboard) you're using
    *Steps to reproduce, if possible
    *Text from any error messages you might be seeing
    *Steps you've taken (if any) to resolve
    *Lines from debug.log that may be relevant
    *Screen captures if absolutely necessary
    *Brief description of your pc config, speed, memory, os, etc.
    '01 Chevy Xtreme Stepside (pics)
    FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
    WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
    350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    Okay I don't know if this is a bug or not but I am going to throw it out there any way. Coming out of "standby", Irman control does not work. If I go into the settings and disable and then enable it, it will work again. It will also work if I exit ME then run it again. Is there a way to make ME re-enable the Irman after coming out of standby?
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    Quote Originally Posted by Naamanf
    This is a known issue and is in the readme.txt
    Get MediaEngine !!!
    Media Engine Download
    Sep 2003
    Colorado
    Quote Originally Posted by CarComp
    All I read in the read me was about the X10 USB having problems. So I take that includes all IR devices?
    2007 Tahoe
    My Install
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    One thing fixed.
    Choosing Hibernate instead of shutdown is a nice option.
    One thing broken.
    Volume forces itself to 0% volume buttons and updown arrows on track/album listings don't work.
    Spec Epia M10000 Nehmiah, DigitalWW USB touch panel, 512meg ram XP Pro SP1 has the same problem when used as application and shell.
    No error message, no listing of consequence in the log, just lack of function to the two sets of up/down(in volume) buttons
    4x4 in a turbo stylee.
    Sep 2002
    St.Louis, MO
    No, there's nothing in the readme about the IRMAN, but any time your IRMAN is powered down it must be initialized in order to work. If we could find some way to know when windows is resuming from standby/hibernation we could probably fix that one. Of course one could equally fault the IRMAN for it's need for a port initialization message before responding.
    FYI, the creative remote's receiver requires no initialization at all.
    Sep 2002
    St.Louis, MO
    Quote Originally Posted by Magenus
    I read another thread that someone was having the same problem im having in regards to ME 2 not removing itself from the os and not reinstalling. I've tried both removing and reinstalling to no success. My system is running xp pro. Is this a bug or am i being a pc dummy? By the way, the program, when it ran, was awesome.
    Does the program run now? What are the symptoms? You mention another thread, but you never let us in on what thread, or what symptoms you're actually seeing. Fscking christ people, read the beginning post and ATTEMPT TO ARTICULATE THE PROBLEM SO WE DON'T HAVE TO READ YOUR MINDS. Installing and uninstalling is a completely different realm than the application's workings, and we really have no time to mess with problems with InstallShield right now. Incidentally, uninstalling / reinstalling is mostly a futile waste of time.
    Here's how to manually uninstall / reinstall the app without ever invoking Add/Remove Programs.
    1) Run unregger.exe in the program directory
    2) Deleting all the .ini, .lst and .m3u files in your program directory
    3) Delete tags.mdb
    4) Double click mediaengine.exe and it will prompt you about registering the activex exes three times
    Sorry that didn't make it into the readme - it should have.
    Sep 2003
    Colorado
    While listening to music and running Copilot, the current song that is playing will finish and the next song will not start untill Copilot quits. Thanks for the info about the Irman.
    2007 Tahoe
    My Install
    Sep 2002
    St.Louis, MO
    Quote Originally Posted by andymitch1971
    What is at the beginning of this threat that says install wmp9 ??
    Nothing, the installer should have prompted you about that, but I haven't tested the build personally on a box w/o wmp9.
    What is at the beginning of the thread is a request for clear consise information about your setup, so we don't have to fill this thread up will bull***** question and answer sessions. I'm a busy person and I figure if you can spend 2 minutes typing to save me 2 hours of asking questions and then waiting on a response, it seems a fair trade for everyone. The only reason we wanted a bug report thread here is so other ppl who might be having the same problems can read it and find out quickly if the issue is resolved or being handled. If you want a question and answer session, drop into #mp3car sometime.
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    phat_bastard, I tested on of the last betas on a machine that didn't have wmp9 installed and got the prompt. Then I installed it and it installed fine
    '98 Explorer Sport
    80% done
