I had the same problem regarding the situation with the uninstall of me 2. I ended up finding that solution lies in the os registry. Once there do a search for mediaengine and it should find the command tree changes and delete them.
Hope that helps.
Please help!
First install, after downloaded the ME 2.0, hang and try to reinstall but keep getting the uninstall screen rather than the install wizard. It keeps asking if I want to completely uninstall the ME 2.0 and I picked yes. Than I tried to install again but keep getting the uninstall wizard. Using Windows add/remove program also cannot uninstall it.
Running windows ME , with XP2100 system.
Appreciate any suggestion on how to manually uninstall ME 2.0 so I can reinstall it. Thanks.
Hope that helps.
I posted a howto in the official bug report thread on how to uninstall / reinstall.Originally Posted by mereg
Not sure if this will let you re-install using the InstallShield build, but there's little reason to do that if you follow the directions.
'01 Chevy Xtreme Stepside (pics)
FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
Hi Guys,Originally Posted by phat_bastard
Tried everything and still can't install/uninstalled ME 2. It showed that it's completely uninstalled but the program is still there and working. The same thing happend in the Window's add/remove program screen.
Also still having the problem playing video. Keep getting message:
"Mediaengine has caused an error in MSDXM.OCX and will now close". Anyone please helps. Thanks in advance.
Running WinMe with all updates and WMP9
