if your laptop has a serial port and "wake on ring" capability you can use that to wake it up. I will not descibe it here but it can be found with the search.
Newb here. Finally dove in thanks to Lilliput. Got it up and running on my Compaq Evo. I set up my display properties to default to the Lilliput screen, so I can keep the notebook closed. If I put it in standby, I can bring it back by simply turning on the screen and touching it.Now, is there any way to recode or write a macro for the Media Engine shutdown button to put this notebook in standby (or hibernate) instead? How much current will it draw on standby? Would hibernate be better?
If I used hibernate and Frodo's shutdown software, how would I power up? I seem to remember reading about software that detected power (ignition on) and booted a laptop, but I searched and now I can't find anything on it.
Thanks!
Mike
[H]4 Life
I'm a lesbian too.
I am for hire!
