Results 1 to 3 of 3
Thread: Any decent visualisations for WMP?
    Oct 2003
    congrats on a good job for the new Mediaengine and I've had no problems so far. However, I've had no luck finding visualisations that are even comparable to Winamps milkdrop. Is there a way to port Milkdrop across or anything or any recommendations on decent vis's. Also a good idea in future releases would be to have preconfigured equaliser settings so you can change it at the press of a button, dsp support and being able to change your balance other than using the global sound settings off the taskbar.So when im the only one in the car I can have the closer speakers turned down a notch so it isn't so weighted to one side. Cheers
    Regards, Michael
    May 2003
    UK
    the tripex website offers a screensaver that will load a winamp visualisation - just install winamp and set its default play file to linein:// then anytime you haven't touched anything for a while your winamp vis will pop up - touch the screen or press a button and it closes. Works seamlessly. only problem is you can't start manually - anyone know how to invoke a screensaver with a hot key or something?
    Newbie b5b4you2's Avatar
    Oct 2003
    San Jose CA
    Quote Originally Posted by Jamez_Warner
    can I get a link to this screen saver, there site seems to not be working very well at the moment. allot of broken links
    Will
