Results 1 to 10 of 10
Thread: mediaengine slow with windows me
    Nov 2003
    hi there,
    i have installed mediaengine 2 under windows me, but it works verry slow!!
    when i startup me the "refreshing database" duration is takes about 3 minutes. i have about 500 mB music on it so that's not the problem. when me is ready, every command i give takes 30 secconds or longer. even when a mp3 is playing and i click on the up arrow to popup the hidden menu, it go's as much slow that i can count the steps it's making to popup the hidden menu.
    i have installed the 2 updates but it stays slow.
    when i install me under windows xp on the same pc it works normaly.
    who knows a selution for this problem?
    greetings qbics
    the cunfugiration of the pc:
    celeron 500 mhz
    192 sdram
    2*20 gig harddisks
    16 mb pci vga
    soundblaster live 5.1
    7 inch lilliput vga touchsreen
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    We haven't "officially" supported Windows Millenium. We do support Windows98 SE, Windows 2000, and Windows XP (which is the OS that MediaEngine is coded on)... Why can't you just use Windows XP?
    -CarComp
    Get MediaEngine !!!
    Media Engine Download
    Nov 2003
    because i can't disable scandisk under xp.
    this evening i am going to instal windows 98 se and see if it work ok.
    greetings qbics
    Oct 2001
    Indiana
    Quote Originally Posted by qbics
    Quit turning off the PC without going to shutdown
    Actually, you can.. View this link
    http://www.winguides.com/registry/display.php/907/
    Get MediaEngine !!!
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    You will probably find that as you are using FAT32, you will get ScanDisk.
    If you use NTFS, then you will hardly ever get ScanDisk, unless it REALLY needs it (in which case, let it run!)
    Anyways, XP without any crap loaded on it should shut down pretty quickly anyway
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Jun 2001
    netherlands
    yep, but it is the cases where my shutdown controller (the oldsyle one) cuts the power after 8 mins.
    stilllooking for the scheme of the advanced controller which sends a signal to go into hibernate.
    hope somebody can help me with that.
    gerard_psx@hotmail.com
    time for the sig:
    '00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
    Nov 2003
    Question
    @ carcomp: i tried the solution which is on the link you told me, but it did't work out. maybe because i have a dutch version of xp??? i don't know.
    @ confused: to change the partition from fat32 to ntfs that will do the job :-). no scandisk and even hibernation works ok.
    greetings qbics.
    Sep 2003
    Quote Originally Posted by CarComp
    -CarComp
    Carcomp, I am having the same problem with extremely slow performance, (almost in a locked state), on two different machines running 98se. I have me2 running perfect on an xp machine. Since it was doing the same thing on two different 98se machines with totally different hardware I've been trying to narrow it down by removing other software. I haven't found anything yet. Both of these machines have 98se with all of the microsoft updates, winamp, power dvd, and keyspan digital media remote software. Any help would be appreciated and if I find anything I will repost.
    Thanks,
    ED
    Oct 2001
    Indiana
    We have an update coming out soon... We just have to finish testing it. We have changed a myriad of things, especially how the db functions, so hopefully this will help you.
    Per chance, did you use the add favorites function? We found that if you are to install m.e 2.0, then run it and build the db, so long as you don't use any "add favorites" features, the db won't take "forever" to load.. This is a bug and has been fixed, but again we are testing.
    Get MediaEngine !!!
    Jun 2001
    netherlands
    i had the same slow performance, for some weird reason, when i set my resolution to 640x480 with the torque 640 skin, it works fine.
    time for the sig:
  1. Replies: 29
    Last Post: 11-13-2003, 06:15 PM
  2. Replies: 4
    Last Post: 10-25-2003, 11:58 PM
  3. windows shutdown script
    By marsjell in forum Software & Software Development
    Last Post: 06-12-2002, 01:24 PM
  4. new windows shell & 'shell=' for win2K
    By magnetik in forum Software & Software Development
    Last Post: 04-16-2002, 09:47 PM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
