must be something isolated to your setup, i run ME on XP pro with no autoshutdown (Crashes) at all. Take a look in the debug.log file and see if theres any helpfull info there as to why its crashing.
does any one have a solution for running media engine on xp pro.. the problem een with the latest updates is that the ME shuts down after 3 sec..
i have two machines and in both don't work ... did it work from the begining or did you do something specail to det it to work...both my machines have xp pro ... and i tried on my brothers he has xp home and i worked fineOriginally Posted by liquid_smoke
I have this problem with WinXP Pro fully patched while running the latest ME2.x. So I just run ME1.77 and I'm good to go![]()
1993 BMW 325is - 15.2sec
I don't have the same problem, win xp pro, fully patched...Originally Posted by SiGmA_X
Wierd problems like this SUCK to debug
+ My 2 cents
[H]4 Life
I'm a lesbian too.
I am for hire!
i was told to
Delete settings.ini
Delete kb.ini
Delete keys.ini
Delete tags.mdb
Delete me_audio.m3u
Delete me_video.m3u
Delete debug.log
Next, run the Unregger.exe file (this releases the activeX exes from the registry)...then run the app again
i haven't try these yet but i'm going to .. for sure
by the way where can i get ME 1.77
it worked on xp from the beginning, ive tested it on about 3 computers at my house and one at work, all running xp pro
Its working on XP Pro now, I clean installed it again. Going to use XPLite in a few min and see if it works![]()
Okay, XP Lite is installed, and ME2 works.. And then it crashes in ~1min or so from startup. Ideas??
