Results 1 to 10 of 19
Thread: Error #91
    Maximum Bitrate SiGmA_X's Avatar
    Jul 2003
    Portland, OR, USA
    Error #91
    I am patched to the latest as of today, and here's the error I'm getting. ME is restarting many times..
    1/6/2004 6:13:46 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:13:48 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:13:50 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:13:52 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:13:54 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:13:56 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:13:58 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:00 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:02 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:07 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:09 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:11 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:14 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:16 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:35 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:37 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:39 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:41 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:43 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:46 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:48 PM - An error occured in modDB.UpdateDB : : Error number 91
    1/6/2004 6:14:50 PM - An error occured in modDB.UpdateDB : : Error number 91
    What would that error be?
    1993 BMW 325is - 15.2sec
    Variable Bitrate mutilator's Avatar
    Jul 2002
    Staffordshire - united kingdom
    number 91.
    sorry
    Jul 2003
    Portland, OR, USA
    Quote Originally Posted by mutilator
    number 91.
    sorry
    Well, what is error #91!?
    Jan 2004
    Hmmm... For a start, what OS are you running?
    Jan 2003
    Ruston, LA
    I would suggest running the unregger and then restarting me
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    Error number 91 indicates that an object variable or with block variable is not set. This translates to some sort of variable was being set to a type of object, only the object didn't want to be created (so to speak) and there was an error.
    I suggest you check your option to install MDAC in the installer.
    Then install m.e
    Get MediaEngine !!!
    Media Engine Download
    Jul 2003
    Portland, OR, USA
    I'll try reinstalling ME, but I did install the MDAC..
    burnout.no - WinXP
    Jan 2004
    Quote Originally Posted by SiGmA_X
    burnout.no - WinXP
    Did you play with xplite?
    Jul 2003
    Portland, OR, USA
    Yes, with XPLite a lot I reinstalled ME and its working now!! I also messed w/ XPLite some more.. Not all sure WHAT I did to fix it.. Any one have ideas? What options need to be set in XPLite to make it work?
    Jan 2004
    Thought so.. Basically, it's nice to install me first.. About the things that can be removed with xplite.. Go ahead and try - see for yourself.. Different systems may require different components.. Just keep a backup!
