Hey all. All the sudden my MediaEngine isn't detecting my PCR anymore. The XM software still picks it up and has good signal strength. But when I went into MediaEngine's Setting for the radio it said XMPCR disabled. So I unchecked the box and then rechecked it. And it doesn't find it. Whats up? Am I missing something?? Its been working great for almost a year now!
It's not what you buy............It's what you build
'01 Chevy Xtreme Stepside (pics)
FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
I never thought to look. I'll have to take a look at that. Its stopped working when my antenna cam disconnected. Not knowing the antenna got disconnected, I unchecked the pcr from under "Radio" and then rechecked it. Media Engine hasn't found it since.
However, i did notice that MediaEngine is looking at com ports. Now, its been awhile, But does the XMPCR use a virtual usb seralizer? Like most gps sensors do? Because it dosn't list the PCR under my comports either. As it shouldn't being its a usb.
I had this happen to me once. Try editing settings.ini in the xmpcr_tuner section and removing the value for "port" and setting "enabled" to false. Then delete xm_channels.dat from your mediaengine folder. If that doesn't work you can set the port value manually if you know which one it is.
Out of curiosity, what version are you running? I only ask because I thought I'd fixed this in 2.3.5.
I'm running your most recent build. How do I find out the port number being used? the xmpcr software doesn't tell me much.
compmgmt.msc > Device Manager > Ports (COM & LPT)
Depending on how your receiver is connected and whether your mainboard has built-in ports, you may have several devices there, or possibly just one. Try them by number until you find the right one.
Yea, it doesn't show the xm. I have my com port, LPT port, gps and some goofy serial usb adaptor. I'm assuming that could be the xm, But Media Engine doesn't find the XM on that port.
Make sure you don't have something else running in the background that might be using that port i.e. the xmpcr app.
I give up. I even tried uninstalling the xm and reinstalling it. Zippo. So I'm going to uninstall the xm and MediaEngine and start over.
