Results 1 to 4 of 4
Thread: IR Compatibility
    Feb 2004
    IR Compatibility
    Is ME compatible with an ATI Remote Wonder I ?
    Feb 2004
    Anyone???
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    maybe if you can find a plug for the ATI wonder remote to use with girder then it will work with any windows program.
    Sep 2003
    Gloucester (UK)
    found this from google search, web site is here http://remotew.free.fr/girder.htm
    Girder
    This automation tool (Girder.nl) can control any application through any inputs (keyboard, mouse, remote...). Girder needs an additional plug-in in order to use the Remote Wonder, and you can choose between the following ones :
    1. The very first plug-in is by Ksnoopy. You need to keep ATI remote software active as this solution just receive remote inputs through a plugin in ATI remote software it and then send the commands to Girder (a second plug-in in Girder receives this commands). This solution works perfectly, and you can keep the mouse pointer function from the remote software.
    2. Ermon (seen on Rage3D forum) created a new plug-in for Girder : "This plugin receives events from the ATI remote wonder, and the X10 family of remotes upon which it is based. This driver connects directly to X10's drivers and bypasses ATI's application and allows use of the 'ATI-Only' buttons (such as Power, TV...)." But you'll loose mouse pointer function (some replacement : post on Rage3D forum).
    Note : if one of these plugins give you too fast reaction... for example, try to assign a button to switch chapters in a DVD, and when you press the correct button, sometimes it jumps two chapters instead of one, then try activating "Only send first match" under "Target" (thanks to Ice =A= on Rage3D forum
  1. IR Help...
    By mattwz in forum General Hardware Discussion
    Last Post: 12-20-2003, 01:57 PM
  2. IR Repeat Speed
    By unrealer33 in forum ME Archive
    Last Post: 06-18-2003, 11:32 PM
  3. Sony joystick remote - IR version
    By brooksy69 in forum General Hardware Discussion
    Last Post: 04-09-2002, 09:09 AM
  4. IR Sensor question...
    By WakeAndSno in forum General Hardware Discussion
    Last Post: 01-17-2002, 04:56 PM
  5. Mobo IR connectors
    By blkdragon6 in forum General Hardware Discussion
    Last Post: 07-07-2000, 02:23 PM
