Ya re-write it!!!
Gday,
I've just tested out me 2.1 and was pretty impressed with the feature updates. The only problem I have with it is the fact that it uses winamp as a music engine instead of 2.0's WMP. Most of my music collection is in WM9 lossless and therefore is not compatible with the winamp engine.
Is there any way I can set ME 2.1 to use WMP??? Would be sooo good if I could get that to funtion.
Thanks for your help,
Dave
Ya re-write it!!!
New CarPC on the way again I think. I miss my old one!!!
Just use ME 2.0, it was based on WMP.
Winamp can play WMA Lossless Files with a simple change to the preferences. To make it play just do this (I'm using Winamp 5 so it may be different for others):
1. Go into the winamp preferences.
2. Click on "Input" listed in the "Plugins" section.
3. Click on "Nullsoft DirectShow Decoder"
4. Click on Configure.
5. add ";WMA" to the extension list.
6. Click OK
7. Click Close
8. Play all your WMA Lossless Files
Originally Posted by kingo102
No Matter what I try I cannot get my wma Files to work in the newest media engine????
I've added the file extension,(in winamp and media engine)
They show up but do not play?/?
SOMEBODY PPPlease Help!!
Thanks Gang![]()
Did you add it to your regular install of winamp or the winamp in the M.E. directory ?Originally Posted by kurtm
[H]4 Life
I'm a lesbian too.
I am for hire!
I don't have a regular winamp install,
and I did it to the one in the ME directory.
I'm having the same problem on my home machine as well as my carpc
any other suggestions??
Thanks for your response![]()
Z3PC
I don't have ME installed at the moment, if I get a chance I'll look around.Originally Posted by kurtm
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
