Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Ditching Mappoint.
  1. #21
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    Quote Originally Posted by skippy76
    I'm an experienced windows programmer and would not mind helping out where I can. The audiable part is pretty easy, however, we would just need to decide upon an acceptable mechanism to solve:
    - If we are off route
    - Doing rerouting
    Has anyone played with Delorme Street Atlas? This does turn by turn, not had a chance to look at SDKs though.
    i had rerouting all done. You just touch a button and it would plot a new route
    '98 Explorer Sport
    80% done
  2. #22
    Mar 2004
    no way to access the mappoint database?
    Asus Pundit Barebones PC
    7" Lilliput LCD
    P4 2.8ghz 512mb 120gb
    Windows XP Pro, VOICES
    Sony Xplode 10in Sub, Rockford 600w amp
    Pioneer 6x9's and 4x6's, Kenwood 4ch amp
    Black Widow Alarm with Pager
  3. #23
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    Ok.... So let's go back to the beginning here. I think most people agree that Mappoint is one of the better products. The reasons against Mappoint were:
    I have decided that mappoint sucks too much to even be part of mediaengine. Its unreliable, the maps don't match current roads, and sometimes it looks like you are driving off the road out in the grass somewhere.
    1) It's unreliable
    2) The maps don't match current roads
    3) Sometimes it looks like you are off the road
    ...1) What is unreliable? It's database is the widest used and therefore is going to the most up to date available.
    ...2) The maps don't match current roads. Obviously using version 2004 we would hope that it is pretty up to date. With the web services, up dates should be available.
    ...3) Sometimes appear off the road. This is a general GPS inaccuracy, GPS is not allways going to be accurate to a couple of meters. Agreed, Mappoint does not have a snap to road function.
    So, let's gather requirements. Reading through so far, I think we are wanting:
    - Turn by turn instructions
    - Voice
    - Rerouting
    - Accurate maps / updates download
    - GPS:
    * Current location (state / road / etc.)
    * Current location Long., Lat., Alt.
    * Speed & Heading
    - Distance to next turn
    - Next turn graphical indication (i.e. graphic showing fork left, fork right etc.)
    - Support multi countries (US, UK, Canada, Europe)
  4. #24
    Mar 2004
    Skippy i would say you just about summed it up. Two things regarding voice:
    Voice recognition - terms like "where am i" "what is my next turn" etc...
    Voice prompts - (ability to enable or disable) "turn left at next intersection - Smith st." etc
    Also when voice prompts come on, music volume is brought down (should be a fairly simple addition)
    7" Lilliput LCD
  5. #25
    May 2002
    Albany, NY
    the reason why carcomp is not using my mappoint code is mainly because of turn by turn. As of this point it just doesn't work 100%. I believe when he was out testing it wasn't even switching to the next turn even though he made the turn. I did a few 8 hour road trips with it and it was about 85% accurate in knowing when the correct turn was made.
    '98 Explorer Sport
    80% done
  6. #26
    Mar 2004
    Cambridge, MA, USA
    Ok, so how can we make it more accurate? What machanism is used in your code to determin when a turn is made? Maybe we can improve upon this or even think of another mechanism. I guess that this turn detection functionaliy is implemented in your code as it does not exist in Mappoint. Therefore, the way I see it (at the moment) is we are dependent on:
    1) Reliability of the GPS
    2) Reliability of the Maps
    3) Sensitivity and accuracy of the turn detection system
    1 & 2 we do not have any control over, however, we could take a look into 3...???
    Regards,
    Andrew
  7. #27
    Mar 2004
    I agree with that i don't see how things could be off if we are using our own app and not mappoint itself. Mappoint is the most extensive mapping system around to my knowledge. note: mapquest.com is based on mappoint.
    7" Lilliput LCD
  8. #28
    Mar 2004
    Cambridge, MA, USA
    Back in 1997 / 1998 I used a product called GeoConcept. This (at the time) was the best product around in terms of SDK and functionality in the cartographic world. Shall not go into too much detail, but I was developing a soil analysis system for the French Goverment.
    This is very widly used, however, with our needs, we need both a substantial database, good SDK and good route finding functionality (plus all the other sutff I mentioned above).
    ryguy: Any chance I could take a loook at what you have developed? Maybe discuss with you the way you've designed it and see if we can come up with any mods etc.
    Andrew
  9. #29
    Mar 2004
    Andrew:
    My apologies if I have come across as a programmer, Iím a systems administrator and do as little programming as possible on a day-to-day basis. Iím just here for suggestions/support
    7" Lilliput LCD
  10. #30
    Mar 2004
    Cambridge, MA, USA
    No problem, maybe I can help you out in someway though. I imagine it's writen in VB6?? Maybe if I could take a look?
    Andrew
  1. Mediacar and Mappoint
    By IIJasonII in forum MediaCar
    Last Post: 03-24-2004, 08:58 AM
  2. Mappoint Not Installed?!?
    By hman in forum MediaCar
    Last Post: 03-06-2004, 06:24 PM
  3. BU-303 with MapPoint 2004?
    By Jeff in forum GPS
    Last Post: 02-18-2004, 09:37 PM
  4. How to integrate MapPoint?!?!
    By deadweasel in forum Software & Software Development
    Last Post: 12-01-2003, 07:56 AM
  5. Which versions of MapPoint will be supported?
    By fluidman in forum ME Archive
    Last Post: 10-06-2003, 09:09 AM
