Make sure you setup the vizualization to have the proper resolution through winamp.
LCD goes out of range when I run any Winamp visualizations, but when I power it off and back on, they are magically working. Same goes for exiting out of the visualizations - the LCD has to be powered off and then back on for the black screen to clear? Anyone else run into any problems like this?
2004 Subaru STI
AMS CG65 2.4Ghz P4 w/512MB DDR, 40GB HD
Audigy2 ZS, Xenarc 700TSV, Gyration Media Center
WinXP Pro, ME 2.1, AudioBahn 5100T Amp
AWT10X Sub, JL XR100-CT tweeters
Sony XPlod fronts, Kenwood Excelon rears
I've done that but I still keep getting the Out of Range errors. Was going to a different vis like someone mentioned before on a similar thread. Any other ideas? Thanks again for your help!
