Results 1 to 10 of 11
Thread: GPS - Confused
    May 2002
    Memphis, TN
    GPS - Confused
    After searching around a bit I cannot find a definative answer on what GPS and GPS software I should use with Media Engine. I am ready to add GPS services to my car but any Media Engine specific recommendations would be helpful...
    Thanks!
    My Current Setup Is Here.
    Jun 2004
    Central California
    Hi, have you found out what ME requires for GPS? I'm a bit puzzled on this too.
    May 2002
    Memphis, TN
    I bought a DeLorme Earthmate GPS Receiver. It works and uses the Street Atlas USAģ 2004 software that can be loaded via ME.
    Jun 2004
    Central California
    What I'm confused with is on ME's setup there's a tab for GPS but it's all blank. And then I learned that it's not deployed yet.
    So do you start your navigation application through the 'External Apps' button then?
    Maximum Bitrate dodgetimes2's Avatar
    MI
    External App, yes. Routis seems to be the only GPS app that has problems lauching from ME though. After you add Routis as an Ext. App. it works once, then if you exit ME and start it up again Routis will not launch (Sound files Missing or Corrupt.....). Hope CarComp and PhatB fix it.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    May 2002
    Memphis, TN
    External app is the way I do it...
    Mac Car Moderator kandyman676's Avatar
    Maryland
    Same here. I use GPS gate with Earthmates USB to serial driver with Netstumbler and Mappoint running as External Programs. No problems!
    "If it works this good why F with it?" -KMFDM "Intro"
    Strive for ethical wardriving: http://faq.wardrive.net/
    My CarCPUs: v1 - 2000 | v2 - 2004
    Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
    nmb
    nmb is offline
    Jun 2004
    So this is not possible yet?
    What software do you recomend with voice guide?
    Feb 2004
    I'd advocate for waiting until Media Engine has integrated Destinator support. Or at least thats what I'm doing.
    I want to get my computer in my car, but I can wait.
    Newbie swifty8083's Avatar
    Jun 2004
    Stafford, VA USA
    I use Earthmate USB GPS, works great and has voice recognition software so you can use voice commands, it also tells you where and when to make turns, even cooler it tells you how fast your are traveling and at what direction. The GPS unit is very accurate, the software (map) has a few mistakes from what Iíve noticed, but where I live there has been a lot of construction and new roads. I would recommend it highly, you can get the software and receiver at best buy for $120-$20(mail in rebate)=$100 or look on ebay, I have seen some good deals. It has a lot of cool features, you can plan a trip, enter in the gas mileage you get, and it will automatically find gas stations that will be convenient for your trip. It will run as an external app but thats allright.
    Dell Laptop PIII,500Mhz,640MBRAM,20GBHD(Sits under the driver seat)7.2" Widescreen,Earthmate USB GPS,FM,DVD Drive,I use a docking station, and it stand-by+shut down automatically after I take the key out(DC power stops). Audio into 9 Speakers + Sub
  1. Replies: 17
    Last Post: 02-19-2007, 05:21 PM
  2. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
  3. Cant get good GPS signal in car.
    By Ricky327 in forum GPS
    Last Post: 01-29-2004, 10:28 PM
  4. Replies: 4
    Last Post: 09-04-2003, 10:20 AM
  5. Music and GPS
    By Mikesz in forum GPS
    Last Post: 02-28-2003, 03:26 AM
