Results 1 to 5 of 5
Thread: How do you upgrade??
    May 2004
    How do you all upgrade your software/add songs to your system? Remove it from your car? Once I get my system up in my truck....I plan on pulling up next to my window and running a cable.
    Dec 2003
    Long Island
    But depending on your setup, you should just be able to remove the hard drive from the case, and install it as a secondary IDE drive in your home PC. Alternatively, many people here have WiFi cards set up in their car and home PCs, forcing instant synchronization when the two become within range. With WiFi you could also share internet access if u have XP/2000 installed on both
    May 2004
    Never thought of WiFi
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    or burn what ever you want to transfer on cd/dvd at home, and take it into your car and do what you have to do
    edit: or usb thumb drive
    rebuilding carpc... kinda..
    Newbie OrangePeel's Avatar
    Nov 2003
    Wellington, New Zealand
    I've tried all sorts of approaches. ME has a built-in filesync system, but it never worked well for me, so I use an external sync proggy. I discovered that WiFi is rediculously slow to load say 200MB of new mp3's across my 11b connection, so I opted for parking in the drive and running some cat5 out the window. This didn't work well at all to my surprise, the speed was slower than wifi. I'm guessing there were problems with ground levels or something, or possibly that my PW60 wasn't quite providing the right voltages to the ethernet controller. Either way onboard epia ethernet didn't work well.
    I ended up using a removeable HD caddy which I just pull out and take inside. Very very fast way to transfer tracks
    89 Celica, CarPC installed, 1st bday :)
    • MediaEngine
    • Epia V8000
    • 80GB WD 7200RPM HD
    • Xenarc 700TS
    • SB Live
    • Opus 90W
    • CIMR100 remote
    • Deluo serial GPS
    • D-Link USB radio wired to power antenna
  1. can you upgrade gps software?
    By kalito in forum GPS
    Last Post: 01-20-2004, 11:29 AM
  2. Anyone ever upgrade a TIVO?
    By bosstone74 in forum Off Topic
    Last Post: 01-03-2004, 01:00 AM
  3. Delorme StreetAtlas 2003 SAPI 4 upgrade
    By gfoulks in forum GPS
    Last Post: 05-08-2003, 01:03 PM
  4. installing win2k upgrade...
    By etrik in forum Off Topic
    Last Post: 07-30-2001, 01:39 PM
  5. can you upgrade a laptop processor?
    By etrik in forum General Hardware Discussion
    Last Post: 06-24-2000, 09:54 PM
