Results 1 to 10 of 16
Thread: having a problem scrolling down using touchscreen
    Nov 2003
    just got the newest mediaengine and set it up all fine. I'm putting everything in my car and checking and testing and i realize i can't page-down or page-up, not scroll up or down using the TouchScreen. I am using the Torque skin and there are two arrows on the far right, up and down. I press them but nothing happens. I get the beep that you get from the screen for touching it but no response. Do i have to enable it or do i have a bug? For now i have assigned keys from my keyboard to do that...as well i had originally assigned buttons from a remote that doesn't work. Could that be interfering with it? Should i clear out all the commands i had set (since i really shouldn't need (or want) to use them anyway since the TS is the way i'd like to go). Some troubleshooting advice would be great!
    Jun 2004
    me too .
    I need you help , thanks.
    go to windows desktop and run your finger down the right hand side of the screen
    check what the mouse pointer does - if it dont follow your finger then no doubt you bought a lilliput screen. They tend to do this - dont know why.
    Just uninstall drivers and reinstall - then dont calibrate at all and it will work better.
    Nov 2003
    my cursor touches it, i calibrated it correctly, when i touch the screen it to scroll up and down it will put the mouse cursor on the down or up arrows...they just don't do anything!
    Low Bitrate QuickCarl's Avatar
    Jun 2003
    Atlanta
    I have the EXACT same problem with the up and down arrows on the Torque skin.
    My screen is calibrated correctly and the touchscreen works properly for all other software.
    Nov 2003
    i'm perplexed...anyone have any pointers?
    Nov 2003
    i'm hoping somebody can answer me this before just switch to mediacar. I really liked this program, i'm hoping there is an easy fix!
    Variable Bitrate peter3's Avatar
    Feb 2001
    The Netherlands (deventer)
    Got yhe same prob. with mij 10.4 touchscreen.
    Also with diverend skins not only torque.
    PETER - THE NETHERLANDS - DEVENTER
    sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
    Nov 2003
    has ANYONE diagnosed this problem, or have any solutions for a fix!?
    Feb 2004
    NYC
    Good... I'm not the only 1 that have this problem... I noticed something else... if you use a mouse...it would work...I unhide my mouse cursor and notice that the pointer is infact working at that area of screen with touchscreen...
    Have anyone tried to change the properties of the touchscreen to be double-click when presses or click when release or something like that? I wanted to try, but didn't have time to look at it..
  1. Touchscreen problem?
    By Pokey in forum MediaCar
    Last Post: 06-04-2004, 06:26 AM
  2. Lilliput touchscreen problem
    By samc in forum Input Devices
    Last Post: 05-09-2004, 11:12 AM
  3. Lilliput touchscreen controller problem
    By JayKaye in forum LCD/Display
    Last Post: 05-05-2004, 07:47 PM
  4. Lilliput touchscreen problem...
    By navig8r in forum LCD/Display
    Last Post: 04-11-2004, 09:56 PM
  5. ps/2 touchscreen problem
    By Odie in forum LCD/Display
    Last Post: 02-20-2003, 05:27 PM
