mabe its gemtek? same as the dlink inside?
try Dlink drivers on it?
tom.
I have a KWORLD Mpeg TV w/ FM tuner.
Its a self powered USB reciever and the FM and audio run into the "audio input" or "line-in" on my computer. I was wondering is there some way to get the FM radio in MediaEngine to run with my set-up. I tried but it wont work, I know I can just run it as an external application but I wanted to know if there is a way to get it working in the MediaEngine interface. It works just like the D-Link but it is supported by KWORLD software but uses the USB and line in just like the D-Link.
tom.
It works fine in windows, the drivers are fine, I am just wondering if there is a way I can configure it to run in the MediaEngine interface? Im not sure if someone else has had this problem
Dell Laptop PIII,500Mhz,640MBRAM,20GBHD(Sits under the driver seat)7.2" Widescreen,Earthmate USB GPS,FM,DVD Drive,I use a docking station, and it stand-by+shut down automatically after I take the key out(DC power stops). Audio into 9 Speakers + Sub
yes but if ur hardware works with the dlink drivers then Media Engine will directly work with it.
Media engine supports Dlink hardware so if it thinks ur tuner is a Dlink it will work within the interface!
