Results 1 to 9 of 9
Thread: USB webcam as reversing aid
    Newbie RobIles's Avatar
    Jun 2004
    UK
    Hello All.
    I'd like to use a (V cheap) webcam - Kodak EZ200 as a revesing aid - as an external app under media engine.
    The camera presents itself to the OS as a TWAIN device.
    Does anybody know of any software that will simply display what the camera sees ? (I dont need anything more than that - the simpler the better!)
    googling for "webcam" returns 99% porn - - - so I thought I'd ask the experts :)
    I may add additional cameras in the future, so if it's possible to specify a command line parameter to choose a cam, all the better!
    freeware/shareware is preferable to commercial.
    Thanks in advance :)
    Rob
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by RobIles
    What makes you think we're the experts on porn??!
    Whilst googling is good, there's also a search button on this site! - EASY rearview camera support (w/ a little help)
    Jun 2004
    UK
    nooo, that wasnt the implication at all
    Thanks for the reply - - I knew about the search, but my keywords were a bit off.
    Cheers
    Rob
    Jun 2004
    UK
    wow! .....the app does exactly what I wanted - - - Thanks for the link, and extra thanks to the developer!!!! very impressed!!
    being new to all this - got a couple of problems though - - if any of you are able to help ?
    1) it defaults to some crappy res - 160 *140 (ish) ......manually change it to 640 * 480 and even my other half could reverse safely ...just a pain to have to do it every time. any way to change this, or is it a driver issue ?
    2) I'm running media engine, not media car. have configured it as an external app, but when I click it (within medie engine) media engine dissapears (it's still in the task list, but GUI dies) ...terminatinf fullscreentv.exe doesnt restore media engine - - need to manually kill it, and re-launch. not ideal. any sugestions, or should I switch to media car ??
    Thanks once again all - - - all help gratefuly recieved!
    Rob
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Hmm... use media car?
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Jun 2004
    UK
    I havent until now. download's just completed - but at 1:30AM, I think i should go to bed and take a look in the morning
    Thanks,
    Rob
    Jan 2003
    Ruston, LA
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jun 2003
    Memphis - TN
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Oct 2003
    Madrid
    Rob
    That should be in the ini file, best to put any questions in the original thread, I think.
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. usb power problem: solved!
    By susman in forum General Hardware Discussion
    Last Post: 08-31-2004, 02:50 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
