Results 1 to 4 of 4
Thread: Problems scrolling and volume control
    Feb 2004
    Question Problems scrolling and volume control
    I have a couple of problems that just came up. I cannot turn my volume up or down using my touchscreen, nor can I scroll my folders while in media engine. I have unistalled/reinstalled, changed back to default skin, ran touchscreen utility, and none have seemed to work. When I hook my mouse up to the computer I can do both just fine. Can anyone help me with this problem? I am using a xenarc touchscreen.
    Thanks.......................Oh yeah is there a way that M.E. won't put music in alphabetical order???
    i too have the same problem...
    Maximum Bitrate phat_bastard's Avatar
    Sep 2002
    St.Louis, MO
    Try searching for 'calibrate touchscreen' in the forums. I'm pretty sure there are some touchscreen settings you need to tweak, and then recalibrate your touchscreen to eliminate this problem.
    '01 Chevy Xtreme Stepside (pics)
    FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
    WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
    350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
    Feb 2004
    I too have had the same problem. It has nothing to do with touch screen settings, recalibration or the like. I proved this by the fact that when I touch the scroll up/down and volume up/down buttons you could see them being selected, although it wouldn't actually do anything. Using a mouse, however, would work. I too did a clean install of media engine but also to no avail.
    I eventually fixed it by trial and error - I disabled then re-enabled touch screen support and the problem's gone away.
