hi works pretty good tried to embed mapmonkey no probs
then PDVD embeds fine but when i exit i get this error (file attached)
I have created an application that implements some new features for launching external applications. The application will try to launch your app, then embed the main window into my application's window. Let me know if you have any problems with it either opening certain applications, or just trouble in general.
DO NOT TRY TO USE THIS APP TO LAUNCH MULTIPLE INSTANCES OF THE SAME APPLICATION! IT WILL SCREW UP! I.E., don't have 2 Internet Explorers open then try to open a third with this app, because it can't tell between the separate instances, they are all grouped into the same processID.
Download the App Launch Test by Clicking Here
Get MediaEngine !!!
Media Engine Download
my destinator map resource down permanently
works pretty good.
I didnt get any of the errors above with PDVD, embeded fine and closed fine.
Got errors with iGuidance though but for some reason i cant repro them now.
If i can get it to give errors again, ill post what the errors are.
