Did you use the safe nlite settings?
Ok, I'm trying to nLite a Windows XP SP2 disk, but every time I do, I get activeX errors.
What, exactly, do I need to leave in for ME to work.
Quick! To the Popemobile!
I tried to just stick them in the "last session.ini" that nLite creates by default, but it didnt work. How exactly would I use them?
Edit: And what the **** did you do to your avatar?
Ever try checking / responding to your email? This is what I sent you two days ago:Originally Posted by BiohazrD
Have you used any sort of utility to speed up / strip down windows? If so, you've probably removed a component of ado / mdac. If not, send me a copy of your debug.log file.
> -----Original Message-----
> From: xxbiohazrdxx@XXXXX.com [mailto:xxbiohazrdxx@XXXXX.com]
> Sent: Tuesday, April 05, 2005 10:00 PM
> To: bugz@mediaengine.org
> Subject: Bug Report: Crash on every startup
'01 Chevy Xtreme Stepside (pics)
FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
Originally Posted by phat_bastard
Odd, I didn't get that. Maybe picked up as spam? I read somewhere in the forums about needing MDAC, so I made a new XP disk and triple checked that Jet and MDAC was in it. Still got the error, are there other dependancies that I am missing? Yesterday, I just did a full WINXP install (huge and godawfully slow) and it worked fine, but I still want to trim the fat.
ADO (ActiveX Data Objects)?Originally Posted by BiohazrD
I'm messing with nLite right now, maybe I can put together a list of what can be safely removed.
I don't have time right now to make a disk and install it, but after a quick glance you need to leave in:
Operating System Options / Jet Database Engine
Operating System Options / MDAC
Services / COM+
There may be more, but I haven't seen anything that jumps out at me.
Ok, that would be the problem, I was leaving out COM+. Thanks, gonna make a new disk.
