same problem hereOriginally Posted by vdoubleu
when i load the gps software (street atlas 2005) from either the main menu or the menu from the mp3 player...the street atlas loads but i am missing ALL the mediaengine buttons. i have no music controls..and i can not exit the gps software. the gps is FULL screen and b/c i am running it from media engine, i do not have a X at the top left or anything. so i am stuck. since i do not have a keyboard, i must restart the computer. help
thanks
can you post a screenshot of the problem?
-Jack
2006 Chrysler 300C AWD
Samsung Galaxy Tab In dash
ok, not the GPS-Prog. but for Example:
Originally Posted by Stephan-HB
Ok i got ya... ill have a file fix when i get home tonight..
I think i know exactly whats wrong.
-Jack
Try replacing this file within mediaengine. let me know if this helps at all..
-Jack
couple problems with the file.
First, i did not have that file to begin with.
Putting it in the GPS directory, nothing changed.
The two files in the GPS directory was default and the new file.
When i deleted the default file, the gps software loaded, then the entire screen went blank except the bottom. On the bottom of the screen was the return button (where it should have been).
I should mention that previously, my problem was that the radio and return buttons showed AS street atlas was loading, but when it finished loading, it disappeared. Now I do not see the gps sw, just the return button. Regardless where i click, I will be returned to the music.
OH, and the guy that posted the pic has a black border...as in you can see that Media Engine is still running in the background. I get nothing. ALL i see is the GPS software. NO border. Just the software full screened but no X in the corner or a bar where the maximize, minimize buttons reside.
For testing and moddeling i use my Notebook, there is a better resolution![]()
i think, there is a problem with the skin. Because, if i use the "audi_V4"-skin, you can see the lower Border, but no Control-Buttons for music on the left.
See Example. Next Problem on the Audi skin: On the main menue i changed the "Naviation" Buttom Funktion in the *.skn and it works fine. But in the Playlist the is a "GPS"-Button who links to "ext.apps." Can I EASY change it?
i can´t find the bottom for "NAVIGATION" for change it. Please help me!!
