- WMA9 Lossless and Pro (applies to Winamp v2.90 to 5.02 only, not 5.03+)
Microsoft recently added the Pro and Lossless profiles to their WMA formats. Unfortunately these are totally different then the normal WMA profile. Therefore, Winamp's default in_wm.dll decoder does not work on these files. It is recommended that you remove in_wm.dll from the plugins folder before doing this. If you do not have WMPv9 installed install
Windows Media 9
Series Codecs Installation Package first. Next add the proper extensions to the DirectShow decoder
