GPS with MapMonkey - Taskbar problem
Hi all,
I have a little problem when using destinator through MapMonkey inside MediaEngine (via MMlauncher). Although I have managed to get MM to embedded inside ME, when ever I open up the GPS page or access the menus in MM/D3 i get the normal windows task bar appearing ontop of ME with the "ME" task label highlighted (eg like MSN message windows are highlighted after a new message).
To say that this is tad anoying is an understatement! :mad: has anyone had the same problem or even found a solution. I havnt tried seting ME to be default shell yet as I would like to get windows avalible at all times.
Versions:
ME 2.3.3 (does the same in 2.3.2)
MM 1.348
D3 - newest maps
