Results 1 to 8 of 8
Thread: M-BUS adaptor with M.E
    Aug 2005
    Has anyone succeded in getting this to work? I have tried everything I can think of. Is it even possible? The plugin is for winamp so I thought it would be cool.
    Maximum Bitrate phat_bastard's Avatar
    Sep 2002
    St.Louis, MO
    I'm not familiar with what this plugin does, but are you putting it in c:\program files\media engine\plugins? Also, if you need to configure the plugin through Winamp, you'll need to run winamp from the media engine folder.
    '01 Chevy Xtreme Stepside (pics)
    FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
    WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
    350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
    Aug 2005
    Yeah thats where I put it. Its the winamp plugin for the M-BUS to usb adaptor made by jbors. It should allow me to use my factory head unit to change track on my PC.
    M-Bus CD changer adapter for car pc integration
    Sep 2002
    St.Louis, MO
    Can you make it work running winamp standalone?
    Sep 2002
    St.Louis, MO
    The changer support of playlists definitely won't work on top of MediaEngine. For changing tracks only I believe it would work. Kind of a neat hack, but there are so many different HU control protocols it has a somewhat limited audience.
    Aug 2005
    The main problem I have with it is: it uses an automated installer. It asks you to point it at your winamp folder and it does the rest. Unfortunately it won't accept any of the folders within M.E as containing winamp. I've been trying to hack a solution from the files it drops when I install it on standalone winamp.
    Re: the protocols - M-BUS covers just about all Alpine head units (AI-Net can be converted) and JBors provides other units for other protocols. He seems to have alot covered.
    May 2005
    Chico, CA
    Why spend money on an Alpine unit and have a carPuter?
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
    Mar 2004
    ^^... uh because people want to have AM/FM radio. Because some people want music when their CarPC is down for maintenance.
  1. Solved: USB bus stays powered after shutdown
    By S4Per in forum Power Supplies
    Last Post: 05-28-2007, 09:09 PM
  2. Need help decoding a one wire databus...
    By Dexter in forum Hardware Development
    Last Post: 03-04-2006, 08:09 PM
  3. What would you do with a bus and $$$$?
    By KyleYankan in forum General MP3Car Discussion
    Last Post: 07-19-2005, 03:14 AM
  4. Class 2 data bus? J1850?
    By Rickertsen2 in forum Hardware Development
    Last Post: 07-15-2005, 04:28 PM
  5. Our skin, 1024x768 -> A 1987 model Scania Bus
    By Knutti in forum MediaCar
    Last Post: 04-27-2005, 10:27 PM
