I'm not sure I understand what you're asking here. You can't assign buttons inside of ME if we don't have functions to assign them to. Maybe what you're wanting is to pass certain keystrokes on to another app, but I can't really tell. If so, then no you can't. If not, please refine your question.Originally Posted by Genesisfactor
I think arrow keys are hardcoded to up, down left and right navigation functions. I'd have to look to be sure. Again, you should probably refine your question.Originally Posted by Genesisfactor
We use winamp 5.0.2 for all audio file playback. You can try to replace it with a newer version but your mileage may vary. Just replace winamp.exe in the M.E. folder, and put any plugins you need in the plugins folder.Originally Posted by Genesisfactor
M.E. is contained primarily in one executable, so functionally the answer to your question is yes.Originally Posted by Genesisfactor
Currently no, but it does save where you have it for each application. You could manually edit your apps.lst and change the third element in each line (the pipe character is the delimiter) to 3 or 4 (I forget which is bottom right).Originally Posted by Genesisfactor
This is not possible. I was planning to make a shutdown menu that would optionally pop up to give you the option to reboot, exit, power down, etc. but I don't think I'll be able to get that into the upcoming release.Originally Posted by Genesisfactor
LinkBack URL
About LinkBacks
Its acutally programmed to Esc. However, i need something that wont' kill the
