Results 1 to 9 of 9
Thread: Embedded GPS problem
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I know i'm supposed to submit the bug report on the website, but there is no way to attach pictures there.
    This is what happens when I try to launch either map monkey or free drive from ME, if I set them up as external applications they work just fine. I have tested this both on my machine in the car and my machine on my desk and they both do it.
    I know it's hard to see but it says memory problem,maybe program already launched. Which I know is not true.
    And this one says INI Data are not saved
    肚子笑痛了
    S60 Install
    Apr 2006
    Has an answer been found for this?
    I am having the same problem with launching map monkey from within Media Engine. I assumed there was no response because the question may have been answered many times. However I have searched this forum for days and still have not found the answer. I understand that other media consoles use a laucher, but I have not seen anything like that for Media Engine.
    How is Map Monkey launched using the GPS button so that it runs embedded?
    May 2003
    Miami, FL
    Yeah I havent heard anything on it, for now i've just been using iguidance to get around it
    肚子笑痛了
    S60 Install
    May 2005
    Submit a bug report on the media engine site and link to this thread...
    Apr 2006
    Seems to be ok
    For some reason (typical) as soon as I posted the problem, it went away. I think what may have been happening is that a mapmonkey instance was still running in memory after I had tried to shut it down, then open it in Media Engine. I have had to manually kill the mapmonkey process on several occations. I think I have run into every issue in the book, but still very impressed with both products. Keep up the good work.
    Variable Bitrate Tim Lake's Avatar
    Oct 2005
    Bedford, UK
    You need to make sure you aren't quitting MapMonkey from it's own menu and you aren't launching it outside Media Engine either.
    Basically ME launches it the first time you use it (after a reboot) and then when you 'close' it using the ME button, it actually stays loaded in memory. If it is opened outside ME first, it will try to run it and you'll get the memory error.
    VIA M10000
    512Mb RAM
    30Gb 2.5" HDD
    Bluetooth, 802.11g, GPS
    Silverstone USB DAC
    Consult (ODB)
    CarTFT K500
    Carnetix P1290
    NLited XP with Road Runner and MapMonkey
    Apr 2006
    Thank you
    Good advice. Thank you.
    May 2003
    Miami, FL
    Yeah mine is still doing it and I get an error after every time I come out of hibernation.
    肚子笑痛了
    S60 Install
    Apr 2006
    This may help
    possible fix, err, bandaid for usb gps/touchscreen suspend/hibernate woes
    perhaps you can leverage this vbscript to kill mapmonkey.exe after resuming from hibernate.
  1. Replies: 91
    Last Post: 11-07-2006, 05:47 PM
  2. problem connecting a GPS
    By Touran in forum Map Monkey
    Last Post: 02-25-2006, 12:08 PM
  3. GPS not found problem
    By ThEScReW in forum GPS
    Last Post: 12-20-2004, 06:39 PM
  4. com port problem for gps in D3
    By FireDJ in forum Map Monkey
    Last Post: 12-10-2004, 05:58 AM
  5. Start embedded gps?
    By Maņana in forum PowerVoice
    Last Post: 11-28-2004, 08:39 PM
