Would you be willing to test a build for me and report back if it's working correctly? I don't have a box I can test XM with and code on simultaneously.
Actually what's happening is the receiver isn't being put back into 'standby' mode so you're still hearing whatever it was tuned to. I'll try to take a look at where this got broken. In the mean time you can set your line in to a muted state from window's mixer app and M/E should maintain that setting whenever you're not listening to XM.Originally Posted by XxAndyxX
Someone else has mentioned this - again I'll look into it. I'm currently trying to isolate a bug that prevents channel changes when the XM receiver 'goes to sleep' - it's the type of thing that's really hard to reproduce and even more difficult to debug, so it could be a while before I look at your issue.Originally Posted by XxAndyxX
LinkBack URL
About LinkBacks
