Results 11 to 20 of 24
Thread: Embedded GPS Problem, Help!
  1. #11
    May 2005
    Thanks CarComp, but I haven't touched a thing with Winamp and I am having the same problems with iguidance as above.
    It's basically an out of the box install. Installed Windows (and everything to go with it), MediaEngine and then iGuidance. Set iGuidance up in ME as the GPS app but it doesn't load correctly.
    I am not sure what I did differently from the first time that it worked, but something is awry.
  2. #12
    May 2005
    No ideas?
  3. #13
    Constant Bitrate jarred's Avatar
    Sep 2000
    Stockton, CA USA
    Quote Originally Posted by sebberry View Post
    I just started having this problem as well, with no changes to my system.
    Please advise. I'm running IG3.0 and the latest version of ME on Windows XP SP2.
    Another thing I noticed is that ME is pegged at 96% CPU usage after you try to launch the GPS.
  4. #14
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    OK Try this.
    Download this file http://www.mediaengine.org/download/iguidetestME.exe
    Put it into your MediaEngine directory. It is a modified mediaengine.exe executable.
    Delete your debug.log file ( or rename it)
    Run iguidetest.exe and then start GPS like you normally would.. You should be presented with a series of messageboxes letting you know what the program is doing. It will be recorded into debug.log as well.
    After its all done, write down what happened and then either email me the results with your attached debug.log or post it all here so I can peruse it.
    If you have trouble getting this exe to run, just do whatever you can to make it work (like making a new settings.ini or using the default M.E skin or running RESET.bat) THE IMPORTANT PART is those messageboxes and the resulting debug.log.
    BTW, if anyone can get me their iguidance executable file that will help me a lot. I'm not REAL sure of which version of iguidance I have (my car computer is out of commision I am designing a new super bright LCD backlight using 75 wide angle high intesity LEDs) and the iguidance company may have changed something in a newer version and broke MediaEngine that way.
    Get MediaEngine !!!
    Media Engine Download
  5. #15
    May 2005
    CarComp, thanks for creating this test app. I didn't realize you had posted here but after giving up on RoadRunner's BS audio interface I thought I would give ME a shot again.
    Here is what happened:
    Deleted log file
    Ran iguidetestME.exe:
    -Had to run reset.bat
    -Performed the db update and set up media directories as prompted
    -Configured ME to use iguidance as the GPS app. (UMPC version but that shouldn't matter)
    In ME main screen:
    -Clicked "GPS System"
    -ME "Loading" screen shows for a moment then is covered up by the iguidance warning
    -Clicked OK in the iguidance warning screen
    -iguidance loads in a reduced size window (looks like it has retained it's size/position from when loaded in Roadrunner)
    Taskbar is showing with "M.E: GPS" taskbar button highlighted
    MediaEngine logging message boxes:
    I moved the iGuidance window out of the way to reveal the ME "loading" screen. The loading image is covered with a MediaEngine box reading "0 - Looking for OK button window"
    I click ok in the ME message box and:
    The taskbar has disappeared and I am back to the black loading screen with:
    "1 - MediaEngine has found #32770 - 65740" I click ok to this and get "2 - NOW I WILL LOOK FOR THE OK BUTTON"
    Then I get: "x - Could Not find OK button, you click it"
    Clicked ok in that.
    Now I receive a ME box "DONE - Now loading Skin"
    Then it works! IG displays properly in ME.
    Here is the logfile:
    MediaEngine Version - Logfile created on 07/11/2006
    07/11/2006 9:52:04 PM - 0 - Looking for OK BUTTON Window
    07/11/2006 9:53:29 PM - 1 - MediaEngine has found #32770 - 65740
    07/11/2006 9:53:50 PM - 2 - NOW I WILL LOOK FOR THE OK BUTTON
    07/11/2006 9:54:32 PM - I have done This stuff
    07/11/2006 9:56:04 PM - MediaEngine terminated cleanly by user
    Of course running reset.bat and then the old version of ME cause the display issues to come back.
    Whatever you did in the new version appears to have corrected the problem!
  6. #16
    May 2005
    bump
  7. #17
    Sep 2000
    Stockton, CA USA
    I second that bump!
  8. #18
    May 2005
    Triple bump!
  9. #19
    May 2005
    I see there was a new release made a couple of weeks ago, but I don't see anything correcting the IG embedding problem in the release notes
  10. #20
    Oct 2001
    Indiana
    Have you tried it with the "hide window border" thing unchecked?
    Get MediaEngine !!!
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. Embedded Destinator - GPS status button doesnt work
    By aoLhaTer in forum CF Bug Reports
    Last Post: 05-11-2005, 02:16 AM
  3. GPS not found problem
    By ThEScReW in forum GPS
    Last Post: 12-20-2004, 06:39 PM
  4. com port problem for gps in D3
    By FireDJ in forum Map Monkey
    Last Post: 12-10-2004, 05:58 AM
  5. Frodoplayer's embedded GPS, which do you like?
    By ddogg_777 in forum FrodoPlayer
    Last Post: 11-07-2004, 09:05 AM
