Results 1 to 5 of 5
Thread: Instalation problem
    Newbie stasik-a4's Avatar
    Aug 2003
    australia
    Instalation problem
    hey guys.... after installing im geting this error.....22/07/2006 3:27:39 PM - An error occured in astart.initAccSense() : Out of memory : Error number 7
    Any one has a solution?
    Jul 2005
    Queens, NY
    Quote Originally Posted by stasik-a4
    While trying out ME on a different PC, I came across similar errors. After some trial and error, I noticed that it only happens with certain skins at a high resolution.
    Use the default skin or set your resolution to 1024x768 or even lower like 800x600. This worked for me right away.
    Fry
    Fry is offline
    Mar 2004
    Hi,
    got the same error with this function but with an error code of -MAX_LONG or what this hughe number is.
    What does that function do?
    I assume no display thing but the ignition/ACC power check within the serial port. But this is disabled by default.
    Fry
    Fry is offline
    Mar 2004
    Hi,
    no replays, strange.
    Anyway. I installed a previous version of ME 2.x, enabled the ACC thing in the setup menue without connecting the port to anything, set it to 45min and it worked.
    Maximum Bitrate phat_bastard's Avatar
    Sep 2002
    St.Louis, MO
    I believe the issue you're seeing here is an error happening in another section of the app that doesn't have the correct error handlers.
    Try the executable listed in this thread and see if you have any different results.
    '01 Chevy Xtreme Stepside (pics)
    FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
    WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
    350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
