Results 1 to 8 of 8
Thread: How do i make girder work with ME as shell?
    Aug 2005
    Padova, Italy
    Hi again guys,
    i'm trying to figure out how to use media engine as shell and run girder on startup... how is that done?
    Do i have to add some command for the gps unit aswell or does it start automatically?
    Seb
    May 2004
    I've never tried this, but can you create a .bat file that runs all the programs you need to run on startup and point to that in your registry as the windows shell?
    Maximum Bitrate phat_bastard's Avatar
    Sep 2002
    St.Louis, MO
    Forgive my ignorance, but since I've never tested it let's just confirm that nothing in the registry key:
    HKCU\Software\Microsoft\Windows\CurrentVersion\Run
    is launched when you use M/E as the shell?
    If that's the case, I guess the better solution to this is to add code to M/E to parse that key and launch what it finds.
    '01 Chevy Xtreme Stepside (pics)
    FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
    WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
    350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
    FLAC alti's Avatar
    NY
    I have code from carshell that runs everything in the startup folder (except for its own exe) when it boots as shell...
    I have to dig it up but i can send it ober to you if its helpful...
    PS I am getting married this weekend, so it might be awhile...
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    Aug 2005
    Padova, Italy
    Quote Originally Posted by phat_bastard View Post
    Could you do that? Thanks, that would be most useful
    Aug 2005
    Padova, Italy
    Quote Originally Posted by alti View Post
    If PhatBastard can add the code to ME so it launches everything in the startup folder would be great but the code from carshell can be useful aswell ;-) Many thanks and congratulations on your marriage!
    Jul 2001
    gpedit.msc, then edit from explorer.exe to girder.exe, after that have girder setup to run media engine on startup/run parameter. works perfect for me. Never any focus issues or anything. For a little bit extra of a seamless look change your windows background to the identical background you have in media engine. It will look beautiful.
    Aug 2005
    Padova, Italy
    Thanks!!! I didn't notice that function in girder
    The background idea works perfect aswell.
    Cheers mate
  1. How i make Dabbar + Trinloc DAB usb work with frodo
    By MagikTriX in forum FrodoPlayer
    Last Post: 09-04-2005, 03:58 PM
  2. How do I make Radio work?
    By wi77iam in forum Centrafuse
    Last Post: 02-22-2005, 07:10 PM
  3. will this make my laptop screen work
    By omlax19 in forum LCD/Display
    Last Post: 04-23-2004, 01:41 PM
  4. What do I need to make this LCD work with compoosite video?
    By pigseye in forum General Hardware Discussion
    Last Post: 02-19-2002, 09:36 PM
  5. Can you make a portable TV work?
    By type2guy in forum General Hardware Discussion
    Last Post: 08-23-1999, 11:39 PM
