Results 1 to 10 of 11
Thread: Problem with ME and Map Monkey
    DCS
    DCS is offline
    Jan 2005
    Winfield, KS
    I am having a problem with the shutdown process when running ME and Map Monkey......when I shut off my car and map monkey is running (as the embedded GPS application) the shut down process will hang (controlled by opus p/s).
    If I run ME and Map Monkey and return to the Home screen in ME and click shutdown it will shut down ok.
    If I am not running Map Monkey it will shut down fine when controlled by the opus.
    Just wondering if anyone else is having this problem, and if so, have you found a solution?
    Also...Thanks for the great frontend!! I have tried all the others and ME is the BEST!!!...been using for about 18 months and except for my shutdown problem all has been working well
    Mar 2006
    I also have the same problem, have been using it for 12 months now and the shutdown problem is the only thing wrong with it. I can't find a way round it. Would be useful if someone could offer something to solve this problem.
    Maximum Bitrate phat_bastard's Avatar
    Sep 2002
    St.Louis, MO
    When I get freed up with work I'll have a look at it and see if there's some issue happening during a shutdown that could hang things up.
    '01 Chevy Xtreme Stepside (pics)
    FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
    WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
    350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
    Mar 2006
    That would be excellent thanks.
    DCS
    DCS is offline
    Jan 2005
    Winfield, KS
    Thank You!!
    BTW I think this is more of a problem with map monkey....I searched their forum and found a couple of other users with the same problem, but no-one came up with any resolution.....
    MM not allowing shutdown
    MapMonkey prevents windows from closing
    Dec 2004
    Sweden
    I resolved this problem some time ago. Think I used some app loader to load Mapmonkey into ME. Now everything works ok and I'm very pleased with this fine frontend! If I only could get the Destinator 6 maps to work somehow....
    I will see if I can find what I did to make it work.
    DCS
    DCS is offline
    Jan 2005
    Winfield, KS
    Thanks...
    May 2005
    Chico, CA
    Adding this to your registry will probably help:
    http://aumha.org/downloads/autoend.zip
    Forces shutdown of apps. MS programs have an annoying tendency to do this.
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
    Oct 2004
    Sydney, Australia
    thanks for reg file, i also had this prob. have not tested it yet tho.
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
    DCS
    DCS is offline
    Jan 2005
    Winfield, KS
    I tried the Reg file, but still have the same problem
