Have you tried 1024X768? I was having the same issue w/Street Atlas and changing the resolution worked perfectly.
Hello,
Freedrive won`t embed properly in ME.
When i click GPS, ME pops a loading screen.
Then freedrive loads and ME is @ the background.
When i exit Freedrive i see the loading screen again, and nothing happens.
Hope there is a solution!
Greetz,
Bunny
I think this is a problem with ME. You'll probably notice that ME is chewing up 99% CPU while it's sitting at the loading screen. I had the same problem except on my system ME was using so much CPU that freedrive would appear to 'stall' during loading.
I read on here somewhere that there is a similar problem with one of the other GPS apps (iGuidance?). Details here: Embedded GPS Problem, Help!
The next release should have a fix for iGuidance which will hopefully fix it for FreeDrive as well.
ok thanks, i`ll stick with Mapmonkey until it`s fixed.
