Results 1 to 10 of 19
Thread: ArCom - IVI
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    ArCom - IVI
    Hi gang,
    I have been trying out IVI images and Simon introduced me this to this new effort. I had it installed for about a week and here's my first look at 0.9.
    Pros:
    - Installation was straightforward. After removing the pre-installed /etc/X11/xorg.conf file -- the touchscreen setup app started and resulted in a working screen with little effort.
    - UI is simple and straight forward.
    - Bluetooth gps works out of box (or so has been reported).
    Cons:
    - Not all the features of the IVI are implemented in this version (ie: photo, dialer, etc). As the layout is now, I'm not sure where they can be added.
    - No options to configure things like bluetooth and audio (although Simon promised those are coming).
    Overall, this effort is something I will keep track of as the UI is significantly better than the default from the standard meego IVI image. You can find the image here: http://www.arcom-ivi.de/index.php?op...emid=8&lang=en
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Very cool. Is this MeeGo 1.1 based?
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    Apr 2008
    yep, it is based on MeeGo 1.1
    Mar 2010
    I was looking for something that was elegant.
    Mar 2010
    Did simon say when the next version will be released? This one just kernel panics.
    Aug 2006
    PA
    Last I heard from Simon it was due out in early Jan....
    Mar 2010
    Thanks for the reply.
    Reading helps.
    So far I've gotten the touch-screen calibration app to start but, it will still loop until xserver is halted.
    It may be a problem with the i915 chipset.
    I'm going to try importing the /usr/lib/dri/i915_dri.so from another computer. They should be compatible.
    Sep 2010
    Exclamation roblem booting up ArCom - IVI after install
    Hello
    I am not sure why this is happening but after I install the ArCom it reboots but gets stuck and keeps on reloading a black screen untill it freezes and says it will stay idle for 5 minutes before reattemting to reload. It seems to be an issue with the xserver as this pops up.... xserver is halted.
    I have tried fresh installs but get the same errors. If anyone has had this problem or anything close would be good if could pitch in any tips I am still researching possible fixes.
    Apr 2008
    Quote Originally Posted by acidflow03 View Post
    Hello
    This was also noticed by Nasa, xorg.conf file disturbing in /etc/X11/xorg.conf.d/
    remove it and it should work. Was calibration working ok?
    cheers
    simon
    ps. this is going to be removed in the coming-up version. It is currently beeing tested with MeeGo 1.2 as OS base.
    Aug 2006
    PA
    So Simon...
    When is the next version due??? Inquiring minds want to know...
  1. Meego IVI Status Thread
    By nasa in forum MeeGo In-Vehicle
    Last Post: 12-01-2010, 06:56 AM
  2. MeeGo IVI 1.0 Released:
    By tripzero in forum MeeGo In-Vehicle
    Last Post: 10-24-2010, 01:40 PM
  3. MeeGo IVI SDK
    By Duesentrieb in forum MeeGo In-Vehicle
    Last Post: 09-09-2010, 01:28 PM
  4. MeeGo IVI 1.0 Released:
    Last Post: 08-02-2010, 05:16 PM
