[ 4079.445]
X.Org X Server 1.9.0
Release Date: 2010-08-20
[ 4079.445] X Protocol Version 11, Revision 0
[ 4079.445] Build Operating System: Linux 2.6.37-4-default i686
[ 4079.445] Current Operating System: Linux localhost.localdomain 2.6.37.6-10.5-adaptation-intel-automotive #1 SMP PREEMPT Thu May 12 21:31:13 UTC 2011 i686
[ 4079.445] Kernel command line: ro root=/dev/sda2 quiet vga=current BOOT_IMAGE=vmlinuz-2.6.37.6-10.5-adaptation-intel-automotive
[ 4079.445] Build Date: 12 May 2011 06:46:58PM
[ 4079.445] Build ID: xorg-x11-server 1.9.0-11.53
[ 4079.445] Current version of pixman: 0.20.0
[ 4079.445] Before reporting problems, check
http://wiki.x.org
to make sure that you have the latest version.
[ 4079.445] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 4079.446] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jun 10 19:24:25 2011
[ 4079.447] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 4079.447] (==) No Layout section. Using the first Screen section.
[ 4079.447] (==) No screen section available. Using defaults.
[ 4079.447] (**) |-->Screen "Default Screen Section" (0)
[ 4079.447] (**) | |-->Monitor "<default monitor>"
[ 4079.448] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 4079.448] (==) Automatically adding devices
[ 4079.448] (==) Automatically enabling devices
[ 4079.448] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[ 4079.448] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 4079.448] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 4079.448] (II) Loader magic: 0x821a9a0
[ 4079.448] (II) Module ABI versions:
[ 4079.448] X.Org ANSI C Emulation: 0.4
[ 4079.448] X.Org Video Driver: 8.0
[ 4079.448] X.Org XInput driver : 11.0
[ 4079.448] X.Org Server Extension : 4.0
[ 4079.450] (--) PCI:*(0:0:2:0) 8086:27a2:10cf:137f rev 3, Mem @ 0xf0200000/524288, 0xe0000000/268435456, 0xf0300000/262144, I/O @ 0x00001800/8
[ 4079.450] (--) PCI: (0:0:2:1) 8086:27a6:10cf:137f rev 3, Mem @ 0xf0280000/524288
[ 4079.450] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 4079.450] (II) LoadModule: "extmod"
[ 4079.451] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 4079.452] (II) Module extmod: vendor="X.Org Foundation"
[ 4079.452] compiled for 1.9.0, module version = 1.0.0
[ 4079.452] Module class: X.Org Server Extension
[ 4079.452] ABI class: X.Org Server Extension, version 4.0
[ 4079.452] (II) Loading extension MIT-SCREEN-SAVER
[ 4079.452] (II) Loading extension XFree86-VidModeExtension
[ 4079.452] (II) Loading extension XFree86-DGA
[ 4079.452] (II) Loading extension DPMS
[ 4079.452] (II) Loading extension XVideo
[ 4079.452] (II) Loading extension XVideo-MotionCompensation
[ 4079.452] (II) Loading extension X-Resource
[ 4079.452] (II) LoadModule: "dbe"
[ 4079.453] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 4079.453] (II) Module dbe: vendor="X.Org Foundation"
[ 4079.453] compiled for 1.9.0, module version = 1.0.0
[ 4079.453] Module class: X.Org Server Extension
[ 4079.453] ABI class: X.Org Server Extension, version 4.0
[ 4079.453] (II) Loading extension DOUBLE-BUFFER
[ 4079.453] (II) LoadModule: "glx"
[ 4079.454] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 4079.454] (II) Module glx: vendor="X.Org Foundation"
[ 4079.454] compiled for 1.9.0, module version = 1.0.0
[ 4079.454] ABI class: X.Org Server Extension, version 4.0
[ 4079.454] (==) AIGLX enabled
[ 4079.454] (II) Loading extension GLX
[ 4079.454] (II) LoadModule: "record"
[ 4079.455] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 4079.455] (II) Module record: vendor="X.Org Foundation"
[ 4079.455] compiled for 1.9.0, module version = 1.13.0
[ 4079.455] Module class: X.Org Server Extension
[ 4079.455] ABI class: X.Org Server Extension, version 4.0
[ 4079.455] (II) Loading extension RECORD
[ 4079.455] (II) LoadModule: "dri"
[ 4079.456] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 4079.456] (II) Module dri: vendor="X.Org Foundation"
[ 4079.456] compiled for 1.9.0, module version = 1.0.0
[ 4079.456] ABI class: X.Org Server Extension, version 4.0
[ 4079.456] (II) Loading extension XFree86-DRI
[ 4079.456] (II) LoadModule: "dri2"
[ 4079.457] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 4079.457] (II) Module dri2: vendor="X.Org Foundation"
[ 4079.457] compiled for 1.9.0, module version = 1.2.0
[ 4079.457] ABI class: X.Org Server Extension, version 4.0
[ 4079.457] (II) Loading extension DRI2
[ 4079.457] (==) Matched intel as autoconfigured driver 0
[ 4079.457] (==) Matched vesa as autoconfigured driver 1
[ 4079.457] (==) Matched fbdev as autoconfigured driver 2
[ 4079.457] (==) Assigned the driver to the xf86ConfigLayout
[ 4079.457] (II) LoadModule: "intel"
[ 4079.458] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 4079.458] (II) Module intel: vendor="X.Org Foundation"
[ 4079.458] compiled for 1.9.0, module version = 2.13.0
[ 4079.458] Module class: X.Org Video Driver
[ 4079.458] ABI class: X.Org Video Driver, version 8.0
[ 4079.458] (II) LoadModule: "vesa"
[ 4079.459] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 4079.459] (II) Module vesa: vendor="X.Org Foundation"
[ 4079.459] compiled for 1.9.0, module version = 2.3.0
[ 4079.459] Module class: X.Org Video Driver
[ 4079.459] ABI class: X.Org Video Driver, version 8.0
[ 4079.459] (II) LoadModule: "fbdev"
[ 4079.460] (WW) Warning, couldn't open module fbdev
[ 4079.460] (II) UnloadModule: "fbdev"
[ 4079.460] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 4079.461] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge, Sandybridge, Sandybridge, Sandybridge, Sandybridge,
[ 4079.464] (II) VESA: driver for VESA chipsets: vesa
[ 4079.464] (++) using VT number 2
[ 4079.464] (WW) Falling back to old probe method for vesa
[ 4079.466] drmOpenDevice: node name is /dev/dri/card0
[ 4079.467] drmOpenDevice: open result is 11, (OK)
[ 4079.467] drmOpenByBusid: Searching for BusID pci:0000:00:02.0
[ 4079.467] drmOpenDevice: node name is /dev/dri/card0
[ 4079.467] drmOpenByBusid: drmOpenMinor returns 11
[ 4079.467] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[ 4079.467] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 4079.467] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 4079.467] (==) intel(0): RGB weight 888
[ 4079.467] (==) intel(0): Default visual is TrueColor
[ 4079.467] (II) intel(0): Integrated Graphics Chipset: Intel(R) 945GM
[ 4079.467] (--) intel(0): Chipset: "945GM"
[ 4079.468] (**) intel(0): Tiling enabled
[ 4079.468] (**) intel(0): SwapBuffers wait enabled
[ 4079.468] (==) intel(0): video overlay key set to 0x101fe
[ 4079.468] (II) intel(0): Output LVDS1 has no monitor section
[ 4079.468] (II) intel(0): found backlight control interface /sys/class/backlight/acpi_video0
[ 4079.492] (II) intel(0): Output VGA1 has no monitor section
[ 4079.722] (II) intel(0): Output TV1 has no monitor section
[ 4079.722] (II) intel(0): EDID for output LVDS1
[ 4079.723] (II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
[ 4079.723] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
[ 4079.723] (II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
[ 4079.723] (II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
[ 4079.723] (II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
[ 4079.723] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
[ 4079.723] (II) intel(0): Not using default mode "896x672" (doublescan mode not supported)
[ 4079.723] (II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
[ 4079.723] (II) intel(0): Not using default mode "960x720" (doublescan mode not supported)
[ 4079.723] (II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
[ 4079.724] (II) intel(0): Not using default mode "320x175" (doublescan mode not supported)
[ 4079.724] (II) intel(0): Not using default mode "320x200" (doublescan mode not supported)
[ 4079.724] (II) intel(0): Not using default mode "360x200" (doublescan mode not supported)
[ 4079.724] (II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
[ 4079.724] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
[ 4079.725] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
[ 4079.725] (II) intel(0): Not using default mode "512x384i" (doublescan mode not supported)
[ 4079.725] (II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
[ 4079.725] (II) intel(0): Not using default mode "1152x864" (exceeds panel dimensions)
[ 4079.725] (II) intel(0): Not using default mode "576x432" (doublescan mode not supported)
[ 4079.725] (II) intel(0): Not using default mode "1280x960" (exceeds panel dimensions)
[ 4079.725] (II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
[ 4079.726] (II) intel(0): Not using default mode "1280x1024" (exceeds panel dimensions)
[ 4079.726] (II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
[ 4079.726] (II) intel(0): Not using default mode "1280x1024" (hsync out of range)
[ 4079.726] (II) intel(0): Not using default mode "1600x1200" (exceeds panel dimensions)
[ 4079.726] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
[ 4079.727] (II) intel(0): Not using default mode "1600x1200" (hsync out of range)
[ 4079.727] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
[ 4079.727] (II) intel(0): Not using default mode "1792x1344" (exceeds panel dimensions)
[ 4079.727] (II) intel(0): Not using default mode "896x672" (doublescan mode not supported)
[ 4079.727] (II) intel(0): Not using default mode "1792x1344" (hsync out of range)
[ 4079.727] (II) intel(0): Not using default mode "1856x1392" (exceeds panel dimensions)
[ 4079.727] (II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
[ 4079.727] (II) intel(0): Not using default mode "1856x1392" (hsync out of range)
[ 4079.728] (II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
[ 4079.728] (II) intel(0): Not using default mode "1920x1440" (exceeds panel dimensions)
[ 4079.728] (II) intel(0): Not using default mode "960x720" (doublescan mode not supported)
[ 4079.728] (II) intel(0): Not using default mode "1920x1440" (hsync out of range)
[ 4079.728] (II) intel(0): Not using default mode "416x312" (doublescan mode not supported)
[ 4079.728] (II) intel(0): Not using default mode "1400x1050" (exceeds panel dimensions)
[ 4079.728] (II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
[ 4079.729] (II) intel(0): Not using default mode "2048x1536" (hsync out of range)
[ 4079.729] (II) intel(0): Not using default mode "1024x768" (doublescan mode not supported)
[ 4079.729] (II) intel(0): Printing probed modes for output LVDS1
[ 4079.729] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 4079.729] (II) intel(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz)
[ 4079.729] (II) intel(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 4079.730] (II) intel(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 4079.730] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 4079.730] (II) intel(0): Modeline "1024x768i"x87.0 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz)
[ 4079.730] (II) intel(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 4079.730] (II) intel(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
[ 4079.730] (II) intel(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 4079.730] (II) intel(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 4079.730] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 4079.730] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 4079.730] (II) intel(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz)
[ 4079.731] (II) intel(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
[ 4079.731] (II) intel(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 4079.731] (II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 4079.731] (II) intel(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz)
[ 4079.731] (II) intel(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz)
[ 4079.731] (II) intel(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz)
[ 4079.755] (II) intel(0): EDID for output VGA1
[ 4079.995] (II) intel(0): EDID for output TV1
[ 4079.995] (II) intel(0): Output LVDS1 connected
[ 4079.995] (II) intel(0): Output VGA1 disconnected
[ 4079.995] (II) intel(0): Output TV1 disconnected
[ 4079.995] (II) intel(0): Using exact sizes for initial modes
[ 4079.995] (II) intel(0): Output LVDS1 using initial mode 1024x768
[ 4079.995] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 4079.995] (II) intel(0): Kernel page flipping support detected, enabling
[ 4079.995] (++) intel(0): DPI set to (120, 120)
[ 4079.995] (II) Loading sub module "fb"
[ 4079.996] (II) LoadModule: "fb"
[ 4079.996] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 4079.997] (II) Module fb: vendor="X.Org Foundation"
[ 4079.997] compiled for 1.9.0, module version = 1.0.0
[ 4079.997] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4079.997] (II) UnloadModule: "vesa"
[ 4079.997] (II) Unloading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 4079.997] (==) Depth 24 pixmap format is 32 bpp
[ 4079.997] (==) intel(0): VideoRam: 262144 KB
[ 4079.998] (II) intel(0): [DRI2] Setup complete
[ 4079.998] (II) intel(0): [DRI2] DRI driver: i915
[ 4079.998] (II) intel(0): Allocated new frame buffer 1024x768 stride 4096, tiled
[ 4079.998] (II) UXA(0): Driver registered support for the following operations:
[ 4079.998] (II) solid
[ 4079.998] (II) copy
[ 4079.998] (II) composite (RENDER acceleration)
[ 4079.999] (II) put_image
[ 4079.999] (II) get_image
[ 4079.999] (==) intel(0): Backing store disabled
[ 4079.999] (==) intel(0): Silken mouse enabled
[ 4079.999] (II) intel(0): Initializing HW Cursor
[ 4080.013] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 4080.015] (==) intel(0): DPMS enabled
[ 4080.016] (II) intel(0): Set up textured video
[ 4080.016] (II) intel(0): Set up overlay video
[ 4080.016] (II) intel(0): direct rendering: DRI2 Enabled
[ 4080.016] (--) RandR disabled
[ 4080.016] (II) Initializing built-in extension Generic Event Extension
[ 4080.016] (II) Initializing built-in extension SHAPE
[ 4080.016] (II) Initializing built-in extension MIT-SHM
[ 4080.016] (II) Initializing built-in extension XInputExtension
[ 4080.016] (II) Initializing built-in extension XTEST
[ 4080.016] (II) Initializing built-in extension BIG-REQUESTS
[ 4080.017] (II) Initializing built-in extension SYNC
[ 4080.017] (II) Initializing built-in extension XKEYBOARD
[ 4080.017] (II) Initializing built-in extension XC-MISC
[ 4080.017] (II) Initializing built-in extension XFIXES
[ 4080.017] (II) Initializing built-in extension RENDER
[ 4080.017] (II) Initializing built-in extension RANDR
[ 4080.017] (II) Initializing built-in extension COMPOSITE
[ 4080.017] (II) Initializing built-in extension DAMAGE
[ 4080.036] (EE) AIGLX error: dlopen of /usr/lib/dri/i915_dri.so failed (/usr/lib/dri/i915_dri.so: cannot open shared object file: No such file or directory)
[ 4080.036] (EE) AIGLX: reverting to software rendering
[ 4080.036] (II) AIGLX: Screen 0 is not DRI capable
[ 4080.043] (II) AIGLX: Loaded and initialized /usr/lib/dri/swrast_dri.so
[ 4080.043] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 4080.044] (II) intel(0): Setting screen physical size to 216 x 162
[ 4080.055] (II) XKB: reuse xkmfile /var/cache/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 4080.068] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 4080.069] (**) Power Button: Applying InputClass "default"
[ 4080.069] (II) LoadModule: "evdev"
[ 4080.069] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 4080.070] (II) Module evdev: vendor="X.Org Foundation"
[ 4080.070] compiled for 1.9.0, module version = 2.4.99
[ 4080.070] Module class: X.Org XInput Driver
[ 4080.070] ABI class: X.Org XInput driver, version 11.0
[ 4080.070] (**) Power Button: always reports core events
[ 4080.070] (**) Power Button: Device: "/dev/input/event2"
[ 4080.076] (--) Power Button: Found keys
[ 4080.076] (II) Power Button: Configuring as keyboard
[ 4080.076] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[ 4080.076] (**) Option "xkb_rules" "evdev"
[ 4080.076] (**) Option "xkb_model" "evdev"
[ 4080.076] (**) Option "xkb_layout" "us"
[ 4080.080] (II) XKB: reuse xkmfile /var/cache/xkb/server-D378AD8F86E560F712A83EE36E4E5E92C595B9BD.xkm
[ 4080.082] (II) config/udev: Adding input device Fujitsu FUJ02E3 (/dev/input/event8)
[ 4080.082] (**) Fujitsu FUJ02E3: Applying InputClass "default"
[ 4080.082] (**) Fujitsu FUJ02E3: always reports core events
[ 4080.082] (**) Fujitsu FUJ02E3: Device: "/dev/input/event8"
[ 4080.088] (--) Fujitsu FUJ02E3: Found keys
[ 4080.088] (II) Fujitsu FUJ02E3: Configuring as keyboard
[ 4080.088] (II) XINPUT: Adding extended input device "Fujitsu FUJ02E3" (type: KEYBOARD)
[ 4080.088] (**) Option "xkb_rules" "evdev"
[ 4080.088] (**) Option "xkb_model" "evdev"
[ 4080.088] (**) Option "xkb_layout" "us"
[ 4080.090] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[ 4080.090] (**) Video Bus: Applying InputClass "default"
[ 4080.090] (**) Video Bus: always reports core events
[ 4080.090] (**) Video Bus: Device: "/dev/input/event3"
[ 4080.096] (--) Video Bus: Found keys
[ 4080.096] (II) Video Bus: Configuring as keyboard
[ 4080.096] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD)
[ 4080.096] (**) Option "xkb_rules" "evdev"
[ 4080.096] (**) Option "xkb_model" "evdev"
[ 4080.096] (**) Option "xkb_layout" "us"
[ 4080.097] (II) config/udev: Adding input device Fujitsu FUJ02B1 (/dev/input/event7)
[ 4080.098] (**) Fujitsu FUJ02B1: Applying InputClass "default"
[ 4080.098] (**) Fujitsu FUJ02B1: always reports core events
[ 4080.098] (**) Fujitsu FUJ02B1: Device: "/dev/input/event7"
[ 4080.104] (--) Fujitsu FUJ02B1: Found keys
[ 4080.104] (II) Fujitsu FUJ02B1: Configuring as keyboard
[ 4080.104] (II) XINPUT: Adding extended input device "Fujitsu FUJ02B1" (type: KEYBOARD)
[ 4080.104] (**) Option "xkb_rules" "evdev"
[ 4080.104] (**) Option "xkb_model" "evdev"
[ 4080.104] (**) Option "xkb_layout" "us"
[ 4080.107] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 4080.107] (**) Power Button: Applying InputClass "default"
[ 4080.108] (**) Power Button: always reports core events
[ 4080.108] (**) Power Button: Device: "/dev/input/event1"
[ 4080.116] (--) Power Button: Found keys
[ 4080.116] (II) Power Button: Configuring as keyboard
[ 4080.116] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[ 4080.116] (**) Option "xkb_rules" "evdev"
[ 4080.116] (**) Option "xkb_model" "evdev"
[ 4080.116] (**) Option "xkb_layout" "us"
[ 4080.117] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 4080.117] (**) Lid Switch: Applying InputClass "default"
[ 4080.118] (**) Lid Switch: always reports core events
[ 4080.118] (**) Lid Switch: Device: "/dev/input/event0"
[ 4080.124] (WW) Lid Switch: Don't know how to use device
[ 4080.140] (II) UnloadModule: "evdev"
[ 4080.140] (EE) PreInit returned NULL for "Lid Switch"
[ 4080.146] (II) config/udev: Adding input device Fujitsu Component USB Touch Panel (/dev/input/event5)
[ 4080.146] (**) Fujitsu Component USB Touch Panel: Applying InputClass "default"
[ 4080.146] (**) Fujitsu Component USB Touch Panel: always reports core events
[ 4080.146] (**) Fujitsu Component USB Touch Panel: Device: "/dev/input/event5"
[ 4080.152] (--) Fujitsu Component USB Touch Panel: Found 3 mouse buttons
[ 4080.152] (--) Fujitsu Component USB Touch Panel: Found absolute axes
[ 4080.152] (--) Fujitsu Component USB Touch Panel: Found x and y absolute axes
[ 4080.152] (II) Fujitsu Component USB Touch Panel: Configuring as mouse
[ 4080.152] (**) Fujitsu Component USB Touch Panel: YAxisMapping: buttons 4 and 5
[ 4080.152] (**) Fujitsu Component USB Touch Panel: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 4080.152] (II) XINPUT: Adding extended input device "Fujitsu Component USB Touch Panel" (type: MOUSE)
[ 4080.152] (II) Fujitsu Component USB Touch Panel: initialized for absolute axes.
[ 4080.153] (II) config/udev: Adding input device Fujitsu Component USB Touch Panel (/dev/input/js0)
[ 4080.153] (**) Fujitsu Component USB Touch Panel: Applying InputClass "default"
[ 4080.153] (**) Fujitsu Component USB Touch Panel: always reports core events
[ 4080.153] (**) Fujitsu Component USB Touch Panel: Device: "/dev/input/js0"
[ 4080.160] (EE) ioctl EVIOCGNAME failed: Invalid argument
[ 4080.176] (II) UnloadModule: "evdev"
[ 4080.176] (EE) PreInit returned NULL for "Fujitsu Component USB Touch Panel"
[ 4080.176] (II) config/udev: Adding input device Fujitsu Component USB Touch Panel (/dev/input/mouse0)
[ 4080.176] (**) Fujitsu Component USB Touch Panel: Applying InputClass "default"
[ 4080.177] (**) Fujitsu Component USB Touch Panel: always reports core events
[ 4080.177] (**) Fujitsu Component USB Touch Panel: Device: "/dev/input/mouse0"
[ 4080.184] (EE) ioctl EVIOCGNAME failed: Inappropriate ioctl for device
[ 4080.200] (II) UnloadModule: "evdev"
[ 4080.200] (EE) PreInit returned NULL for "Fujitsu Component USB Touch Panel"
[ 4080.205] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 4080.205] (**) AT Translated Set 2 keyboard: Applying InputClass "default"
[ 4080.205] (**) AT Translated Set 2 keyboard: always reports core events
[ 4080.205] (**) AT Translated Set 2 keyboard: Device: "/dev/input/event4"
[ 4080.212] (--) AT Translated Set 2 keyboard: Found keys
[ 4080.212] (II) AT Translated Set 2 keyboard: Configuring as keyboard
[ 4080.212] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
[ 4080.212] (**) Option "xkb_rules" "evdev"
[ 4080.212] (**) Option "xkb_model" "evdev"
[ 4080.212] (**) Option "xkb_layout" "us"
[ 4080.213] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event6)
[ 4080.214] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "default"
[ 4080.214] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "synaptics"
[ 4080.214] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[ 4080.214] (II) LoadModule: "synaptics"
[ 4080.215] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 4080.215] (II) Module synaptics: vendor="X.Org Foundation"
[ 4080.215] compiled for 1.9.0, module version = 1.3.0
[ 4080.215] Module class: X.Org XInput Driver
[ 4080.216] ABI class: X.Org XInput driver, version 11.0
[ 4080.216] (II) Synaptics touchpad driver version 1.3.0
[ 4080.216] (**) Option "Device" "/dev/input/event6"
[ 4080.256] (--) SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5472
[ 4080.256] (--) SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4448
[ 4080.256] (--) SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[ 4080.256] (--) SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[ 4080.256] (--) SynPS/2 Synaptics TouchPad: buttons: left right double triple scroll-buttons
[ 4080.288] (--) SynPS/2 Synaptics TouchPad: touchpad found
[ 4080.288] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 4080.304] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD)
[ 4080.304] (**) SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[ 4080.304] (**) SynPS/2 Synaptics TouchPad: MaxSpeed is now 1.75
[ 4080.304] (**) SynPS/2 Synaptics TouchPad: AccelFactor is now 0.040
[ 4080.304] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 4080.304] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[ 4080.304] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 4080.304] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 4080.328] (--) SynPS/2 Synaptics TouchPad: touchpad found
[ 4080.328] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[ 4080.328] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "default"
[ 4080.328] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "synaptics"
[ 4080.328] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[ 4080.328] (II) Synaptics touchpad driver version 1.3.0
[ 4080.736] (EE) SynPS/2 Synaptics TouchPad no synaptics event device found
[ 4080.736] (**) Option "Device" "/dev/input/mouse1"
[ 4080.744] (--) SynPS/2 Synaptics TouchPad: invalid x-axis range. defaulting to 1615 - 5685
[ 4080.744] (--) SynPS/2 Synaptics TouchPad: invalid y-axis range. defaulting to 1729 - 4171
[ 4080.744] (--) SynPS/2 Synaptics TouchPad: invalid pressure range. defaulting to 0 - 256
[ 4080.744] (--) SynPS/2 Synaptics TouchPad: invalid finger width range. defaulting to 0 - 16
[ 4080.764] (EE) Query no Synaptics: 6003C8
[ 4080.764] (--) SynPS/2 Synaptics TouchPad: no supported touchpad found
[ 4080.765] (EE) SynPS/2 Synaptics TouchPad Unable to query/initialize Synaptics hardware.
[ 4080.777] (EE) PreInit failed for input device "SynPS/2 Synaptics TouchPad"
[ 4080.777] (II) UnloadModule: "synaptics"
[ 4080.957] (II) Power Button: Close
[ 4080.957] (II) UnloadModule: "evdev"
[ 4080.969] (II) Fujitsu FUJ02E3: Close
[ 4080.969] (II) UnloadModule: "evdev"
[ 4080.985] (II) Video Bus: Close
[ 4080.985] (II) UnloadModule: "evdev"
[ 4081.001] (II) Fujitsu FUJ02B1: Close
[ 4081.001] (II) UnloadModule: "evdev"
[ 4081.007] (II) Power Button: Close
[ 4081.007] (II) UnloadModule: "evdev"
[ 4081.017] (II) Fujitsu Component USB Touch Panel: Close
[ 4081.017] (II) UnloadModule: "evdev"
[ 4081.025] (II) AT Translated Set 2 keyboard: Close
[ 4081.025] (II) UnloadModule: "evdev"
[ 4081.044] (II) UnloadModule: "synaptics"
