Results 11 to 20 of 29
Thread: Meego 1.2 has been released
  1. #11
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    aindfan,
    I started the hints in my 1st post... Here's more detailed info:
    1. On releases of IVI after about 3 May the text install is the only one that will work (they integrated the emgd driver and broke the GUI install for all machines not supported by that driver)
    2. Related to #1, once installed you will have to remove the emgd drivers and install the mesa gles drivers. It helps if you grab a copy of an image released last week (there was an error in the inittab file which put it into runlevel 3 vs 5 -- which is cool for our purposes as it's tricky to get to a virtual terminal when the GUI is *trying* to run). If you don't get one of those images, you will have to wait for a break in xorg trying to start. During that break, switch to a VT. Once in the VT, you will have to do something like:
    "rpm -e --nodeps emgd.bin"
    "zypper install mesa-libEGL"
    "zypper install mesa-libEGL-compat"
    "zypper install mesa-libGLESv1"
    "zypper install mesa-libGLESv2"
    "zypper install mesa-libGLESv2-compat"
    Note: you may not have to run ever line -- zypper may install some due to dependencies. This also requires a network connection... If you aren't using a image with the error, you need to type quick!
    3. reboot
  2. #12
    Aug 2006
    PA
    Moystard,
    I haven't really worked on that feature yet. Be aware, it's limited to only the desktop (ividesktop) right now. See here: http://wiki.meego.com/In-vehicle/IVIHome_Guide
  3. #13
    Jun 2011
    Thank you for the documentation, I knew it was only available for IVI Home but did not know about this wiki page.
  4. #14
    Apr 2011
    Thanks nasa. I'm sort of given up on getting MeeGo up and running right now, but I would like to try installing IVI home/desktop on my Ubuntu setup. Any tips on getting up and running, or do I just keep trying to run it and copy in a library every time an error message comes up that it's missing? I'm using Ubuntu 11.04 x86, and I'll post the error message when I get a chance (I've started installing library dependencies already).
    Thanks again!
  5. #15
    Aug 2006
    PA
    aindfan,
    I haven't tried to install just the UX on something outside of the base distro. It would be nice if there was deb releases of the IVI (as you know, it's all rpm). Alien should work as the rpm's are suppose to meet the LSB. Keep us posted on your progress, and I will try and help where I can.
  6. #16
    Apr 2011
    ivihome seems to be working now that I made it through all of the dependencies... I'd like to figure out a way to make it the default window manager (if it is a window manager?). It's definitely much no-look friendlier than Ubuntu's gnome defaults. ividesktop doesn't run, however, giving some message about an invalid pixmap.
    Any thoughts on which packages I should install?
    (The most important problem is that the default evdev touchscreen driver is a bit jumpy - the cursor likes to zip to the left edge of the screen when clicking you touch somewhere else. I wasn't having much luck installing the eGalax driver but I'll try again.)
  7. #17
    Aug 2006
    PA
  8. #18
    Mar 2011
    Marietta, Ohio
    Quote Originally Posted by nasa View Post
    aindfan,
    3. reboot
    Thanks for the tips. I am running the same hardware as you from a fujitsu lifebook, but cannot seem to get this to work with your explicit instuctions from above. I am still getting the INIT: Id "x" respawning too fast: disabled for 5 minutes intel core 2 duo and intel 945g graphics... could you provide any assistance?
  9. #19
    Aug 2006
    PA
    Sorry for taking so long to get back... Take a look at the /etc/X11/ directory. If there is an xorg.conf file there, remove it. In the xorg.conf.d directory remove the tsc* file. Post your /var/log/Xorg.0.log file if those steps don't work.
  10. #20
    Mar 2011
    Marietta, Ohio
    No problem. I appreciate your willingness to help. I must admit I haven't been doing much with Linux lately and am a bit rusty. Still could not get x to work. Working on getting you that log file if I can. Bare with me, I'll run a livecd and grab the file as it's the easiest way I know to get it.
    [ 4079.445]
    X.Org X Server 1.9.0
    Release Date: 2010-08-20
    [ 4079.445] X Protocol Version 11, Revision 0
    [ 4079.445] Build Operating System: Linux 2.6.37-4-default i686
    [ 4079.445] Current Operating System: Linux localhost.localdomain 2.6.37.6-10.5-adaptation-intel-automotive #1 SMP PREEMPT Thu May 12 21:31:13 UTC 2011 i686
    [ 4079.445] Kernel command line: ro root=/dev/sda2 quiet vga=current BOOT_IMAGE=vmlinuz-2.6.37.6-10.5-adaptation-intel-automotive
    [ 4079.445] Build Date: 12 May 2011 06:46:58PM
    [ 4079.445] Build ID: xorg-x11-server 1.9.0-11.53
    [ 4079.445] Current version of pixman: 0.20.0
    [ 4079.445] Before reporting problems, check http://wiki.x.org
    to make sure that you have the latest version.
    [ 4079.445] Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    [ 4079.446] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jun 10 19:24:25 2011
    [ 4079.447] (==) Using config directory: "/etc/X11/xorg.conf.d"
    [ 4079.447] (==) No Layout section. Using the first Screen section.
    [ 4079.447] (==) No screen section available. Using defaults.
    [ 4079.447] (**) |-->Screen "Default Screen Section" (0)
    [ 4079.447] (**) | |-->Monitor "<default monitor>"
    [ 4079.448] (==) No monitor specified for screen "Default Screen Section".
    Using a default monitor configuration.
    [ 4079.448] (==) Automatically adding devices
    [ 4079.448] (==) Automatically enabling devices
    [ 4079.448] (==) FontPath set to:
    catalogue:/etc/X11/fontpath.d,
    built-ins
    [ 4079.448] (==) ModulePath set to "/usr/lib/xorg/modules"
    [ 4079.448] (II) The server relies on udev to provide the list of input devices.
    If no devices become available, reconfigure udev or disable AutoAddDevices.
    [ 4079.448] (II) Loader magic: 0x821a9a0
    [ 4079.448] (II) Module ABI versions:
    [ 4079.448] X.Org ANSI C Emulation: 0.4
    [ 4079.448] X.Org Video Driver: 8.0
    [ 4079.448] X.Org XInput driver : 11.0
    [ 4079.448] X.Org Server Extension : 4.0
    [ 4079.450] (--) PCI:*(0:0:2:0) 8086:27a2:10cf:137f rev 3, Mem @ 0xf0200000/524288, 0xe0000000/268435456, 0xf0300000/262144, I/O @ 0x00001800/8
    [ 4079.450] (--) PCI: (0:0:2:1) 8086:27a6:10cf:137f rev 3, Mem @ 0xf0280000/524288
    [ 4079.450] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
    [ 4079.450] (II) LoadModule: "extmod"
    [ 4079.451] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
    [ 4079.452] (II) Module extmod: vendor="X.Org Foundation"
    [ 4079.452] compiled for 1.9.0, module version = 1.0.0
    [ 4079.452] Module class: X.Org Server Extension
    [ 4079.452] ABI class: X.Org Server Extension, version 4.0
    [ 4079.452] (II) Loading extension MIT-SCREEN-SAVER
    [ 4079.452] (II) Loading extension XFree86-VidModeExtension
    [ 4079.452] (II) Loading extension XFree86-DGA
    [ 4079.452] (II) Loading extension DPMS
    [ 4079.452] (II) Loading extension XVideo
    [ 4079.452] (II) Loading extension XVideo-MotionCompensation
    [ 4079.452] (II) Loading extension X-Resource
    [ 4079.452] (II) LoadModule: "dbe"
    [ 4079.453] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
    [ 4079.453] (II) Module dbe: vendor="X.Org Foundation"
    [ 4079.453] compiled for 1.9.0, module version = 1.0.0
    [ 4079.453] Module class: X.Org Server Extension
    [ 4079.453] ABI class: X.Org Server Extension, version 4.0
    [ 4079.453] (II) Loading extension DOUBLE-BUFFER
    [ 4079.453] (II) LoadModule: "glx"
    [ 4079.454] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
    [ 4079.454] (II) Module glx: vendor="X.Org Foundation"
    [ 4079.454] compiled for 1.9.0, module version = 1.0.0
    [ 4079.454] ABI class: X.Org Server Extension, version 4.0
    [ 4079.454] (==) AIGLX enabled
    [ 4079.454] (II) Loading extension GLX
    [ 4079.454] (II) LoadModule: "record"
    [ 4079.455] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
    [ 4079.455] (II) Module record: vendor="X.Org Foundation"
    [ 4079.455] compiled for 1.9.0, module version = 1.13.0
    [ 4079.455] Module class: X.Org Server Extension
    [ 4079.455] ABI class: X.Org Server Extension, version 4.0
    [ 4079.455] (II) Loading extension RECORD
    [ 4079.455] (II) LoadModule: "dri"
    [ 4079.456] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
    [ 4079.456] (II) Module dri: vendor="X.Org Foundation"
    [ 4079.456] compiled for 1.9.0, module version = 1.0.0
    [ 4079.456] ABI class: X.Org Server Extension, version 4.0
    [ 4079.456] (II) Loading extension XFree86-DRI
    [ 4079.456] (II) LoadModule: "dri2"
    [ 4079.457] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
    [ 4079.457] (II) Module dri2: vendor="X.Org Foundation"
    [ 4079.457] compiled for 1.9.0, module version = 1.2.0
    [ 4079.457] ABI class: X.Org Server Extension, version 4.0
    [ 4079.457] (II) Loading extension DRI2
    [ 4079.457] (==) Matched intel as autoconfigured driver 0
    [ 4079.457] (==) Matched vesa as autoconfigured driver 1
    [ 4079.457] (==) Matched fbdev as autoconfigured driver 2
    [ 4079.457] (==) Assigned the driver to the xf86ConfigLayout
    [ 4079.457] (II) LoadModule: "intel"
    [ 4079.458] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
    [ 4079.458] (II) Module intel: vendor="X.Org Foundation"
    [ 4079.458] compiled for 1.9.0, module version = 2.13.0
    [ 4079.458] Module class: X.Org Video Driver
    [ 4079.458] ABI class: X.Org Video Driver, version 8.0
    [ 4079.458] (II) LoadModule: "vesa"
    [ 4079.459] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
    [ 4079.459] (II) Module vesa: vendor="X.Org Foundation"
    [ 4079.459] compiled for 1.9.0, module version = 2.3.0
    [ 4079.459] Module class: X.Org Video Driver
    [ 4079.459] ABI class: X.Org Video Driver, version 8.0
    [ 4079.459] (II) LoadModule: "fbdev"
    [ 4079.460] (WW) Warning, couldn't open module fbdev
    [ 4079.460] (II) UnloadModule: "fbdev"
    [ 4079.460] (EE) Failed to load module "fbdev" (module does not exist, 0)
    [ 4079.461] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
    i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
    E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
    965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
    4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
    Sandybridge, Sandybridge, Sandybridge, Sandybridge, Sandybridge,
    [ 4079.464] (II) VESA: driver for VESA chipsets: vesa
    [ 4079.464] (++) using VT number 2
    [ 4079.464] (WW) Falling back to old probe method for vesa
    [ 4079.466] drmOpenDevice: node name is /dev/dri/card0
    [ 4079.467] drmOpenDevice: open result is 11, (OK)
    [ 4079.467] drmOpenByBusid: Searching for BusID pci:0000:00:02.0
    [ 4079.467] drmOpenDevice: node name is /dev/dri/card0
    [ 4079.467] drmOpenByBusid: drmOpenMinor returns 11
    [ 4079.467] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
    [ 4079.467] (II) intel(0): Creating default Display subsection in Screen section
    "Default Screen Section" for depth/fbbpp 24/32
    [ 4079.467] (==) intel(0): Depth 24, (--) framebuffer bpp 32
    [ 4079.467] (==) intel(0): RGB weight 888
    [ 4079.467] (==) intel(0): Default visual is TrueColor
    [ 4079.467] (II) intel(0): Integrated Graphics Chipset: Intel(R) 945GM
    [ 4079.467] (--) intel(0): Chipset: "945GM"
    [ 4079.468] (**) intel(0): Tiling enabled
    [ 4079.468] (**) intel(0): SwapBuffers wait enabled
    [ 4079.468] (==) intel(0): video overlay key set to 0x101fe
    [ 4079.468] (II) intel(0): Output LVDS1 has no monitor section
    [ 4079.468] (II) intel(0): found backlight control interface /sys/class/backlight/acpi_video0
    [ 4079.492] (II) intel(0): Output VGA1 has no monitor section
    [ 4079.722] (II) intel(0): Output TV1 has no monitor section
    [ 4079.722] (II) intel(0): EDID for output LVDS1
    [ 4079.723] (II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
    [ 4079.723] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
    [ 4079.723] (II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
    [ 4079.723] (II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
    [ 4079.723] (II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
    [ 4079.723] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
    [ 4079.723] (II) intel(0): Not using default mode "896x672" (doublescan mode not supported)
    [ 4079.723] (II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
    [ 4079.723] (II) intel(0): Not using default mode "960x720" (doublescan mode not supported)
    [ 4079.723] (II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
    [ 4079.724] (II) intel(0): Not using default mode "320x175" (doublescan mode not supported)
    [ 4079.724] (II) intel(0): Not using default mode "320x200" (doublescan mode not supported)
    [ 4079.724] (II) intel(0): Not using default mode "360x200" (doublescan mode not supported)
    [ 4079.724] (II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
    [ 4079.724] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
    [ 4079.725] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
    [ 4079.725] (II) intel(0): Not using default mode "512x384i" (doublescan mode not supported)
    [ 4079.725] (II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
    [ 4079.725] (II) intel(0): Not using default mode "1152x864" (exceeds panel dimensions)
    [ 4079.725] (II) intel(0): Not using default mode "576x432" (doublescan mode not supported)
    [ 4079.725] (II) intel(0): Not using default mode "1280x960" (exceeds panel dimensions)
    [ 4079.725] (II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
    [ 4079.726] (II) intel(0): Not using default mode "1280x1024" (exceeds panel dimensions)
    [ 4079.726] (II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
    [ 4079.726] (II) intel(0): Not using default mode "1280x1024" (hsync out of range)
    [ 4079.726] (II) intel(0): Not using default mode "1600x1200" (exceeds panel dimensions)
    [ 4079.726] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
    [ 4079.727] (II) intel(0): Not using default mode "1600x1200" (hsync out of range)
    [ 4079.727] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
    [ 4079.727] (II) intel(0): Not using default mode "1792x1344" (exceeds panel dimensions)
    [ 4079.727] (II) intel(0): Not using default mode "896x672" (doublescan mode not supported)
    [ 4079.727] (II) intel(0): Not using default mode "1792x1344" (hsync out of range)
    [ 4079.727] (II) intel(0): Not using default mode "1856x1392" (exceeds panel dimensions)
    [ 4079.727] (II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
    [ 4079.727] (II) intel(0): Not using default mode "1856x1392" (hsync out of range)
    [ 4079.728] (II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
    [ 4079.728] (II) intel(0): Not using default mode "1920x1440" (exceeds panel dimensions)
    [ 4079.728] (II) intel(0): Not using default mode "960x720" (doublescan mode not supported)
    [ 4079.728] (II) intel(0): Not using default mode "1920x1440" (hsync out of range)
    [ 4079.728] (II) intel(0): Not using default mode "416x312" (doublescan mode not supported)
    [ 4079.728] (II) intel(0): Not using default mode "1400x1050" (exceeds panel dimensions)
    [ 4079.728] (II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
    [ 4079.729] (II) intel(0): Not using default mode "2048x1536" (hsync out of range)
    [ 4079.729] (II) intel(0): Not using default mode "1024x768" (doublescan mode not supported)
    [ 4079.729] (II) intel(0): Printing probed modes for output LVDS1
    [ 4079.729] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
    [ 4079.729] (II) intel(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz)
    [ 4079.729] (II) intel(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
    [ 4079.730] (II) intel(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
    [ 4079.730] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
    [ 4079.730] (II) intel(0): Modeline "1024x768i"x87.0 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz)
    [ 4079.730] (II) intel(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
    [ 4079.730] (II) intel(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
    [ 4079.730] (II) intel(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
    [ 4079.730] (II) intel(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
    [ 4079.730] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
    [ 4079.730] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
    [ 4079.730] (II) intel(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz)
    [ 4079.731] (II) intel(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
    [ 4079.731] (II) intel(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
    [ 4079.731] (II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
    [ 4079.731] (II) intel(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz)
    [ 4079.731] (II) intel(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz)
    [ 4079.731] (II) intel(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz)
    [ 4079.755] (II) intel(0): EDID for output VGA1
    [ 4079.995] (II) intel(0): EDID for output TV1
    [ 4079.995] (II) intel(0): Output LVDS1 connected
    [ 4079.995] (II) intel(0): Output VGA1 disconnected
    [ 4079.995] (II) intel(0): Output TV1 disconnected
    [ 4079.995] (II) intel(0): Using exact sizes for initial modes
    [ 4079.995] (II) intel(0): Output LVDS1 using initial mode 1024x768
    [ 4079.995] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
    [ 4079.995] (II) intel(0): Kernel page flipping support detected, enabling
    [ 4079.995] (++) intel(0): DPI set to (120, 120)
    [ 4079.995] (II) Loading sub module "fb"
    [ 4079.996] (II) LoadModule: "fb"
    [ 4079.996] (II) Loading /usr/lib/xorg/modules/libfb.so
    [ 4079.997] (II) Module fb: vendor="X.Org Foundation"
    [ 4079.997] compiled for 1.9.0, module version = 1.0.0
    [ 4079.997] ABI class: X.Org ANSI C Emulation, version 0.4
    [ 4079.997] (II) UnloadModule: "vesa"
    [ 4079.997] (II) Unloading /usr/lib/xorg/modules/drivers/vesa_drv.so
    [ 4079.997] (==) Depth 24 pixmap format is 32 bpp
    [ 4079.997] (==) intel(0): VideoRam: 262144 KB
    [ 4079.998] (II) intel(0): [DRI2] Setup complete
    [ 4079.998] (II) intel(0): [DRI2] DRI driver: i915
    [ 4079.998] (II) intel(0): Allocated new frame buffer 1024x768 stride 4096, tiled
    [ 4079.998] (II) UXA(0): Driver registered support for the following operations:
    [ 4079.998] (II) solid
    [ 4079.998] (II) copy
    [ 4079.998] (II) composite (RENDER acceleration)
    [ 4079.999] (II) put_image
    [ 4079.999] (II) get_image
    [ 4079.999] (==) intel(0): Backing store disabled
    [ 4079.999] (==) intel(0): Silken mouse enabled
    [ 4079.999] (II) intel(0): Initializing HW Cursor
    [ 4080.013] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
    [ 4080.015] (==) intel(0): DPMS enabled
    [ 4080.016] (II) intel(0): Set up textured video
    [ 4080.016] (II) intel(0): Set up overlay video
    [ 4080.016] (II) intel(0): direct rendering: DRI2 Enabled
    [ 4080.016] (--) RandR disabled
    [ 4080.016] (II) Initializing built-in extension Generic Event Extension
    [ 4080.016] (II) Initializing built-in extension SHAPE
    [ 4080.016] (II) Initializing built-in extension MIT-SHM
    [ 4080.016] (II) Initializing built-in extension XInputExtension
    [ 4080.016] (II) Initializing built-in extension XTEST
    [ 4080.016] (II) Initializing built-in extension BIG-REQUESTS
    [ 4080.017] (II) Initializing built-in extension SYNC
    [ 4080.017] (II) Initializing built-in extension XKEYBOARD
    [ 4080.017] (II) Initializing built-in extension XC-MISC
    [ 4080.017] (II) Initializing built-in extension XFIXES
    [ 4080.017] (II) Initializing built-in extension RENDER
    [ 4080.017] (II) Initializing built-in extension RANDR
    [ 4080.017] (II) Initializing built-in extension COMPOSITE
    [ 4080.017] (II) Initializing built-in extension DAMAGE
    [ 4080.036] (EE) AIGLX error: dlopen of /usr/lib/dri/i915_dri.so failed (/usr/lib/dri/i915_dri.so: cannot open shared object file: No such file or directory)
    [ 4080.036] (EE) AIGLX: reverting to software rendering
    [ 4080.036] (II) AIGLX: Screen 0 is not DRI capable
    [ 4080.043] (II) AIGLX: Loaded and initialized /usr/lib/dri/swrast_dri.so
    [ 4080.043] (II) GLX: Initialized DRISWRAST GL provider for screen 0
    [ 4080.044] (II) intel(0): Setting screen physical size to 216 x 162
    [ 4080.055] (II) XKB: reuse xkmfile /var/cache/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
    [ 4080.068] (II) config/udev: Adding input device Power Button (/dev/input/event2)
    [ 4080.069] (**) Power Button: Applying InputClass "default"
    [ 4080.069] (II) LoadModule: "evdev"
    [ 4080.069] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
    [ 4080.070] (II) Module evdev: vendor="X.Org Foundation"
    [ 4080.070] compiled for 1.9.0, module version = 2.4.99
    [ 4080.070] Module class: X.Org XInput Driver
    [ 4080.070] ABI class: X.Org XInput driver, version 11.0
    [ 4080.070] (**) Power Button: always reports core events
    [ 4080.070] (**) Power Button: Device: "/dev/input/event2"
    [ 4080.076] (--) Power Button: Found keys
    [ 4080.076] (II) Power Button: Configuring as keyboard
    [ 4080.076] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
    [ 4080.076] (**) Option "xkb_rules" "evdev"
    [ 4080.076] (**) Option "xkb_model" "evdev"
    [ 4080.076] (**) Option "xkb_layout" "us"
    [ 4080.080] (II) XKB: reuse xkmfile /var/cache/xkb/server-D378AD8F86E560F712A83EE36E4E5E92C595B9BD.xkm
    [ 4080.082] (II) config/udev: Adding input device Fujitsu FUJ02E3 (/dev/input/event8)
    [ 4080.082] (**) Fujitsu FUJ02E3: Applying InputClass "default"
    [ 4080.082] (**) Fujitsu FUJ02E3: always reports core events
    [ 4080.082] (**) Fujitsu FUJ02E3: Device: "/dev/input/event8"
    [ 4080.088] (--) Fujitsu FUJ02E3: Found keys
    [ 4080.088] (II) Fujitsu FUJ02E3: Configuring as keyboard
    [ 4080.088] (II) XINPUT: Adding extended input device "Fujitsu FUJ02E3" (type: KEYBOARD)
    [ 4080.088] (**) Option "xkb_rules" "evdev"
    [ 4080.088] (**) Option "xkb_model" "evdev"
    [ 4080.088] (**) Option "xkb_layout" "us"
    [ 4080.090] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
    [ 4080.090] (**) Video Bus: Applying InputClass "default"
    [ 4080.090] (**) Video Bus: always reports core events
    [ 4080.090] (**) Video Bus: Device: "/dev/input/event3"
    [ 4080.096] (--) Video Bus: Found keys
    [ 4080.096] (II) Video Bus: Configuring as keyboard
    [ 4080.096] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD)
    [ 4080.096] (**) Option "xkb_rules" "evdev"
    [ 4080.096] (**) Option "xkb_model" "evdev"
    [ 4080.096] (**) Option "xkb_layout" "us"
    [ 4080.097] (II) config/udev: Adding input device Fujitsu FUJ02B1 (/dev/input/event7)
    [ 4080.098] (**) Fujitsu FUJ02B1: Applying InputClass "default"
    [ 4080.098] (**) Fujitsu FUJ02B1: always reports core events
    [ 4080.098] (**) Fujitsu FUJ02B1: Device: "/dev/input/event7"
    [ 4080.104] (--) Fujitsu FUJ02B1: Found keys
    [ 4080.104] (II) Fujitsu FUJ02B1: Configuring as keyboard
    [ 4080.104] (II) XINPUT: Adding extended input device "Fujitsu FUJ02B1" (type: KEYBOARD)
    [ 4080.104] (**) Option "xkb_rules" "evdev"
    [ 4080.104] (**) Option "xkb_model" "evdev"
    [ 4080.104] (**) Option "xkb_layout" "us"
    [ 4080.107] (II) config/udev: Adding input device Power Button (/dev/input/event1)
    [ 4080.107] (**) Power Button: Applying InputClass "default"
    [ 4080.108] (**) Power Button: always reports core events
    [ 4080.108] (**) Power Button: Device: "/dev/input/event1"
    [ 4080.116] (--) Power Button: Found keys
    [ 4080.116] (II) Power Button: Configuring as keyboard
    [ 4080.116] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
    [ 4080.116] (**) Option "xkb_rules" "evdev"
    [ 4080.116] (**) Option "xkb_model" "evdev"
    [ 4080.116] (**) Option "xkb_layout" "us"
    [ 4080.117] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
    [ 4080.117] (**) Lid Switch: Applying InputClass "default"
    [ 4080.118] (**) Lid Switch: always reports core events
    [ 4080.118] (**) Lid Switch: Device: "/dev/input/event0"
    [ 4080.124] (WW) Lid Switch: Don't know how to use device
    [ 4080.140] (II) UnloadModule: "evdev"
    [ 4080.140] (EE) PreInit returned NULL for "Lid Switch"
    [ 4080.146] (II) config/udev: Adding input device Fujitsu Component USB Touch Panel (/dev/input/event5)
    [ 4080.146] (**) Fujitsu Component USB Touch Panel: Applying InputClass "default"
    [ 4080.146] (**) Fujitsu Component USB Touch Panel: always reports core events
    [ 4080.146] (**) Fujitsu Component USB Touch Panel: Device: "/dev/input/event5"
    [ 4080.152] (--) Fujitsu Component USB Touch Panel: Found 3 mouse buttons
    [ 4080.152] (--) Fujitsu Component USB Touch Panel: Found absolute axes
    [ 4080.152] (--) Fujitsu Component USB Touch Panel: Found x and y absolute axes
    [ 4080.152] (II) Fujitsu Component USB Touch Panel: Configuring as mouse
    [ 4080.152] (**) Fujitsu Component USB Touch Panel: YAxisMapping: buttons 4 and 5
    [ 4080.152] (**) Fujitsu Component USB Touch Panel: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
    [ 4080.152] (II) XINPUT: Adding extended input device "Fujitsu Component USB Touch Panel" (type: MOUSE)
    [ 4080.152] (II) Fujitsu Component USB Touch Panel: initialized for absolute axes.
    [ 4080.153] (II) config/udev: Adding input device Fujitsu Component USB Touch Panel (/dev/input/js0)
    [ 4080.153] (**) Fujitsu Component USB Touch Panel: Applying InputClass "default"
    [ 4080.153] (**) Fujitsu Component USB Touch Panel: always reports core events
    [ 4080.153] (**) Fujitsu Component USB Touch Panel: Device: "/dev/input/js0"
    [ 4080.160] (EE) ioctl EVIOCGNAME failed: Invalid argument
    [ 4080.176] (II) UnloadModule: "evdev"
    [ 4080.176] (EE) PreInit returned NULL for "Fujitsu Component USB Touch Panel"
    [ 4080.176] (II) config/udev: Adding input device Fujitsu Component USB Touch Panel (/dev/input/mouse0)
    [ 4080.176] (**) Fujitsu Component USB Touch Panel: Applying InputClass "default"
    [ 4080.177] (**) Fujitsu Component USB Touch Panel: always reports core events
    [ 4080.177] (**) Fujitsu Component USB Touch Panel: Device: "/dev/input/mouse0"
    [ 4080.184] (EE) ioctl EVIOCGNAME failed: Inappropriate ioctl for device
    [ 4080.200] (II) UnloadModule: "evdev"
    [ 4080.200] (EE) PreInit returned NULL for "Fujitsu Component USB Touch Panel"
    [ 4080.205] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
    [ 4080.205] (**) AT Translated Set 2 keyboard: Applying InputClass "default"
    [ 4080.205] (**) AT Translated Set 2 keyboard: always reports core events
    [ 4080.205] (**) AT Translated Set 2 keyboard: Device: "/dev/input/event4"
    [ 4080.212] (--) AT Translated Set 2 keyboard: Found keys
    [ 4080.212] (II) AT Translated Set 2 keyboard: Configuring as keyboard
    [ 4080.212] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
    [ 4080.212] (**) Option "xkb_rules" "evdev"
    [ 4080.212] (**) Option "xkb_model" "evdev"
    [ 4080.212] (**) Option "xkb_layout" "us"
    [ 4080.213] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event6)
    [ 4080.214] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "default"
    [ 4080.214] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "synaptics"
    [ 4080.214] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
    [ 4080.214] (II) LoadModule: "synaptics"
    [ 4080.215] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
    [ 4080.215] (II) Module synaptics: vendor="X.Org Foundation"
    [ 4080.215] compiled for 1.9.0, module version = 1.3.0
    [ 4080.215] Module class: X.Org XInput Driver
    [ 4080.216] ABI class: X.Org XInput driver, version 11.0
    [ 4080.216] (II) Synaptics touchpad driver version 1.3.0
    [ 4080.216] (**) Option "Device" "/dev/input/event6"
    [ 4080.256] (--) SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5472
    [ 4080.256] (--) SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4448
    [ 4080.256] (--) SynPS/2 Synaptics TouchPad: pressure range 0 - 255
    [ 4080.256] (--) SynPS/2 Synaptics TouchPad: finger width range 0 - 15
    [ 4080.256] (--) SynPS/2 Synaptics TouchPad: buttons: left right double triple scroll-buttons
    [ 4080.288] (--) SynPS/2 Synaptics TouchPad: touchpad found
    [ 4080.288] (**) SynPS/2 Synaptics TouchPad: always reports core events
    [ 4080.304] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD)
    [ 4080.304] (**) SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
    [ 4080.304] (**) SynPS/2 Synaptics TouchPad: MaxSpeed is now 1.75
    [ 4080.304] (**) SynPS/2 Synaptics TouchPad: AccelFactor is now 0.040
    [ 4080.304] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
    [ 4080.304] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
    [ 4080.304] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
    [ 4080.304] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
    [ 4080.328] (--) SynPS/2 Synaptics TouchPad: touchpad found
    [ 4080.328] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
    [ 4080.328] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "default"
    [ 4080.328] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "synaptics"
    [ 4080.328] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
    [ 4080.328] (II) Synaptics touchpad driver version 1.3.0
    [ 4080.736] (EE) SynPS/2 Synaptics TouchPad no synaptics event device found
    [ 4080.736] (**) Option "Device" "/dev/input/mouse1"
    [ 4080.744] (--) SynPS/2 Synaptics TouchPad: invalid x-axis range. defaulting to 1615 - 5685
    [ 4080.744] (--) SynPS/2 Synaptics TouchPad: invalid y-axis range. defaulting to 1729 - 4171
    [ 4080.744] (--) SynPS/2 Synaptics TouchPad: invalid pressure range. defaulting to 0 - 256
    [ 4080.744] (--) SynPS/2 Synaptics TouchPad: invalid finger width range. defaulting to 0 - 16
    [ 4080.764] (EE) Query no Synaptics: 6003C8
    [ 4080.764] (--) SynPS/2 Synaptics TouchPad: no supported touchpad found
    [ 4080.765] (EE) SynPS/2 Synaptics TouchPad Unable to query/initialize Synaptics hardware.
    [ 4080.777] (EE) PreInit failed for input device "SynPS/2 Synaptics TouchPad"
    [ 4080.777] (II) UnloadModule: "synaptics"
    [ 4080.957] (II) Power Button: Close
    [ 4080.957] (II) UnloadModule: "evdev"
    [ 4080.969] (II) Fujitsu FUJ02E3: Close
    [ 4080.969] (II) UnloadModule: "evdev"
    [ 4080.985] (II) Video Bus: Close
    [ 4080.985] (II) UnloadModule: "evdev"
    [ 4081.001] (II) Fujitsu FUJ02B1: Close
    [ 4081.001] (II) UnloadModule: "evdev"
    [ 4081.007] (II) Power Button: Close
    [ 4081.007] (II) UnloadModule: "evdev"
    [ 4081.017] (II) Fujitsu Component USB Touch Panel: Close
    [ 4081.017] (II) UnloadModule: "evdev"
    [ 4081.025] (II) AT Translated Set 2 keyboard: Close
    [ 4081.025] (II) UnloadModule: "evdev"
    [ 4081.044] (II) UnloadModule: "synaptics"
    & LSPCI for good measure...
    ubuntu@ubuntu:~$ lspci
    00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
    00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller (rev 03)
    00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
    00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 02)
    00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 02)
    00:1c.2 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 3 (rev 02)
    00:1d.0 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #1 (rev 02)
    00:1d.1 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 02)
    00:1d.2 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 02)
    00:1d.3 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 02)
    00:1d.7 USB Controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 02)
    00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
    00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
    00:1f.2 SATA controller: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA AHCI Controller (rev 02)
    00:1f.3 SMBus: Intel Corporation N10/ICH 7 Family SMBus Controller (rev 02)
    02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8055 PCI-E Gigabit Ethernet Controller (rev 12)
    05:00.0 Ethernet controller: Atheros Communications Inc. AR5001 Wireless Network Adapter (rev 01)
    08:03.0 CardBus bridge: O2 Micro, Inc. OZ6933/711E1 CardBus/SmartCardBus Controller (rev 20)
    08:03.1 CardBus bridge: O2 Micro, Inc. OZ6933/711E1 CardBus/SmartCardBus Controller (rev 20)
    ubuntu@ubuntu:~$
  1. MeeGo 1.1 has just been released
    By Penzance in forum MeeGo In-Vehicle
    Last Post: 10-28-2010, 05:28 PM
  2. MeeGo IVI 1.0 Released:
    By tripzero in forum MeeGo In-Vehicle
    Last Post: 10-24-2010, 01:40 PM
  3. MeeGo IVI SDK
    By Duesentrieb in forum MeeGo In-Vehicle
    Last Post: 09-09-2010, 01:28 PM
  4. MeeGo IVI 1.0 Released:
    Last Post: 08-02-2010, 05:16 PM
